Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: Meego 1.2 has been released
  1. #21
    Maximum Bitrate nasa's Avatar
    Aug 2006
    PA
    Here's your problem:
    [ 4080.036] (EE) AIGLX error: dlopen of /usr/lib/dri/i915_dri.so failed (/usr/lib/dri/i915_dri.so: cannot open shared object file: No such file or directory)
    you need to install mesa-dri-i1915 (it's in the meego repo)
    Note: for those reading this, there is also a mesa-dri-i965 in the repo for those whom may need it...
  2. #22
    Jun 2011
    Hello everybody.
    I'm also trying to install meego1.2 on my laptop lenovo X60s Core Duo 1.6 i915. Encounter absolutly the same trouble as Sall did.
    after I
    Code:
    zypper install mesa-dri-i915-driver
    and rebooted
    X seems have been loaded but it only shows black screen with X-cursor on it.
    what else should be done to get to that fancy meego desktop?
  3. #23
    Aug 2006
    PA
    fsmart,
    Have you followed the steps I wrote up in an earlier post (of this thread)? Could you post your /var/log/Xorg.0.log file (try and attach it instead of posting inline)
  4. #24
    Jun 2011
    NASA Yes, I followed all the steps you've mentioned here. Here's my zipped Xorg.0 log file attached. Thanks for your help)
    Attached Files Attached Files
  5. #25
    Aug 2006
    PA
    fsmart,
    Could you post your /home/meego/.xsession-errors file? Only errors I saw in the log file was relating to your tracpoint (touchpad, right?), which shouldn't stop the desktop from showing up.
  6. #26
    Jun 2011
    nasa,
    oh boy, it's about 1.5 gig size ))
    I truncated the tail, it's the same
    Code:
    "/usr/bin/applauncherd.bin" Connection timeout when waiting for packet 3 Retrying.
    the remaining part that has some useful stuff attached
  7. #27
    Aug 2006
    PA
    I haven't seen this error before -- I'm looking into it...
  8. #28
    Aug 2006
    PA
    BTW: some discussion of similar issues are here: http://forum.meego.com/showthread.php?t=3446
  9. #29
    Aug 2006
    PA
    Quote Originally Posted by nasa View Post
    1. Install for non supported platforms takes more knowledge of Linux
    2. Only supported inputs are touchscreen, mouse, keyboard (limited), and the contour scroll wheel
    3. mounting external usb drives/flash drives is still buggy
    4. No intuitive way to turn-off screen lock function and/or powering of monitor
    5. Hands Free dialer not working
    The IVI team released 1.2.0.1 within the last week and it fixed the locked screen problem (which makes a hug difference). There are some additional driver support in that release as well. The usb mounting problem, while not in the 1.2.0.1 release, has been fixed. To solve it upgrade the kernel and add gvfs support, this also fixes a tracker issue I failed to identify in the orginal post. One can connect your bluetooh phone to Meego and use the Hands Free Dialer to recieve/place calls -- however audio (ie: hearing the caller or caller hearing you) is still along the lines of YMMV.
  1. MeeGo 1.1 has just been released
    By Penzance in forum MeeGo In-Vehicle
    Last Post: 10-28-2010, 05:28 PM
  2. MeeGo IVI 1.0 Released:
    By tripzero in forum MeeGo In-Vehicle
    Last Post: 10-24-2010, 01:40 PM
  3. MeeGo IVI SDK
    By Duesentrieb in forum MeeGo In-Vehicle
    Last Post: 09-09-2010, 01:28 PM
  4. MeeGo IVI 1.0 Released:
    Last Post: 08-02-2010, 05:16 PM
