Results 1 to 4 of 4
Thread: Bluetooth GPS Problems
    Variable Bitrate UnusuallyGenius's Avatar
    Mar 2009
    Grand Rapids, Mi
    I have the BT-328 Bluetooth GPS Receiver by GlobalSat.
    I also have a IOGear USB Bluetooth Chip
    Windows 7 Ultimate with a Widcomm Bluetooth stack.
    When I pair the device with the computer it assigns two virtual serial ports, ports three and four.
    Three is incoming, four is outgoing. Both are set the Baud Rate of 38400 as per GlobalSat instructions.
    When I go into S&T 2010, and tell it to detect the ports, it detects port three, says the GPS is on it. But when you go to start the GPS in S&T it says the port is available, but is not sending any data. How do I fix this problem? Please and thank you.
    - Check out OpenMobile
    - OSDash
    FLAC Marvin Hlavac's Avatar
    May 2005
    It is possible that it is working just fine the way you have set it up, but simply the GPS receiver is not receiving sufficiently good signal from the satellites because you are testing this indoor. Take it outdoor, and test again. See if Streets & Trips works then.
    Review: Streets and Trips 2010
    Mar 2009
    Grand Rapids, Mi
    Quote Originally Posted by Marvin Hlavac View Post
    No, i am sitting in my truck with this. I know there are idiots out there that would try this in their basement, In the middle of a parking lot, in broad daylight. When using GPSGate it works fine. 9 Sats actually. So there is not a problem with the GPS Unit, nor S&T. It is elsewhere. I cannot believe that the only solution is to use GPSGate.
    - OSDash
    May 2005
    Streets & Trips will only work with 4800.
  1. Replies: 65
    Last Post: 10-13-2009, 06:51 PM
  2. Replies: 7
    Last Post: 04-03-2007, 01:47 PM
  3. GPS problems - Dev Edition
    By Lancewindew in forum StreetDeck
    Last Post: 07-12-2006, 10:35 AM
Tags for this Thread
