Results 1 to 10 of 20
Thread: Ideas for using Mimics
    Variable Bitrate super-fly's Avatar
    Feb 2006
    NJ
    I have all my apps neatly organized in folders on one screen along with a HTC clock widget. The problem I have is that the widget doesn't scale right or display correctly using rotator. Also, in the car there are a handful of useful apps, I don't want to have to gok through all my folders to get to them. What I would like to be able to do, ideally with an sbsettings toggle, is turn on rotator and spring jump to say screen 3(which would be my car screen) when I toggle it on. Then toggle off return to home screen and turn off rotator. Also, I would like to be able to create app shortcuts (not sure if there is a way to do this) that link to the actual app. That way I can just put all the app shortcuts on my car screen instead of the actual app because I want to keep them in the folders they are in on my home screen because I will still use them not in the car. Any ideas or anyone able to do this would be great.
    FKA CivicModz
    Mar 2011
    Australia
    Yes, you clock widget was made for portrait view and not landscape. With the jumping of the springboard, there is a free tweak called "SpringJumps" in cydia that will do this really well. What it does is create an icon with an arrow and a page number on it, and you can also name these icons as well. The "mimics driver" has two actions available in activator called "mimics connected" and "mimics disconnected", you can assign these to anything. The issue at the moment is that actions cannot be multiple, i.e. only one action per gesture at the moment.
    In regards to shortcuts, there is "appLinks" but this only works with the appstore apps. What I can suggest is to have all you "InCar" apps on your last springboard page and use "SpringJumps" to get to that page when in "In Car" mode.
    Feb 2006
    NJ
    I do have springjumps which I was going to use to jump to the "car" screen, it would be nice however to somehow combine activating sbrotator, the jump, and activate mimics all with one icon or toggle in sbsettings. Then by toggling it off jump back home, turn of rotator, and unlink mimics.
    FKA CivicModz
    Mar 2011
    Australia
    OK, I see. You don't need to link and unlink mimics, the "mimics driver" does this automatically when you dock/undock the phone. The only thing missing here is multiple actions triggered from a single gesture.
    Mimics has the two triggers and all the actions are already there, all that is needed is some way of having a "list" of actions to perform when an action is performed. This is not possible at this time but I cant see why it cannot be easily implemented. The reason the mimics actions were added were specifically for this reason.
    Feb 2006
    NJ
    I looked at applinks and it doesn't create shortcuts on springboard; it create links to apps within ifile or ssh is all. You can create shortcuts for webpages on the springboard, if only they could be edited some how to link to apps instead.
    FKA CivicModz
    Mar 2011
    Australia
    Sorry, you can try "applicationDuplicator". You need to run this using a terminal. It basically duplicates the app so you can install another copy of it. I had trouble getting this to work though.
    There is another way of duplicating appstore apps HERE, but if you update one you will have to update both!!
    So yes, a true link/shortcut to an app will be really useful.
    You can also try this:
    URL="http://www.ifans.com/forums/showthread.php?t=278908
    Feb 2006
    NJ
    I'll look into one of these, however I didn't really want to have to duplicate the app. Having two of the same app takes double the space, but in the mean time I guess this is the only option.
    FKA CivicModz
    Mar 2011
    Australia
    There must be a way of properly linking an app, just haven't figured it out yet! The last link I posted apparently links only the app but copies the original .png and .plist files, so the extra space wont be much. I just cant get it working yet even after modifying the .plist and a respring. If you figure something out, let us know.
    Variable Bitrate daclothe's Avatar
    Dec 2004
    Have you tried VoiceActivator?
    http://www.youtube.com/watch?v=RrVgvTgyUs8
    Feb 2006
    NJ
    Are there activator actions for springjumps though?
  1. Introducing Mimics. The ultimate iPhone-in-your-car experience
    By optikalefx in forum Mp3Car Blog Talk
    Last Post: 11-16-2015, 09:31 PM
  2. Mimics Delight - Jailbreakme.com Released
    Last Post: 07-07-2011, 02:17 PM
  3. Replies: 0
    Last Post: 05-20-2011, 04:45 PM
  4. Ideas for BMW 325 E30
    By dgmorr in forum Fabrication
    Last Post: 09-21-2006, 12:13 PM
  5. Replies: 0
    Last Post: 04-25-2005, 04:09 PM
