Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Think I foubd BUG with map monkey and media car
  1. #11
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    Not yet
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
  2. #12
    Variable Bitrate cdevelasco's Avatar
    Dec 2004
    Miami, FL / Caracas, Venezuela
    Go NM! I'm rooting for you on this one
  3. #13
    Dec 2004
    Thank You So Much!
    You did it NM! Downloaded your launcher, set it up as instructed, and now it all works! I am usig the executable with the Adv GPS fix, and I am able to open and close Map Monkey through the X in media car AS MANY times as I want without getting an error. PERFECT! got all the functionality I wanted. Once more Thanks so much.
    Now just wanted to point something out not sure if you are aware. I just wanted to try the Sapi plugin to see how it works. I noticed (by checking the taskmanager) that when you press the X to exit, the Map Monkey.exe file now manages to close, however the Sapi Plugin stays in the task manager, when I reopen the GPS I get another instance opf the SAPIPlugin executable and my CPU usage goes all the way to 100%, the first instance of the sapi plugin is hoggin up all the processing power. I manually close the first sapiplugin and then cpu usage goes down to an acceptable 7%. Not a big deal at all, Guess I won't use the sappi plugin, don't want my CPU to overheat. but just wanted to make you aware of this just in case you already didn't know.
  4. #14
    Aug 2003
    Warrington, UK
    I actually noticed this myself tonight while creating the launcher!
    I've placed some checks in the plugins to close themselves if map monkey is no longer running (map monkey is supposed to close them itself but if it crashes or is forced to quit then they are left running)
    They'll be updated with the upcoming hotfix
  5. #15
    Dec 2004
    Cool, Sounds good to me, can't wait for the hot fix, I really think that sapi thing is a cool feature. good luck
  1. RELEASE: Map Monkey v1.1.3
    By Ninja Monkey in forum Map Monkey
    Last Post: 02-12-2009, 10:27 AM
  2. Map Monkey v1.1.3 BETA 3
    Last Post: 03-29-2005, 08:50 AM
  3. Replies: 3
    Last Post: 02-03-2005, 12:11 PM
  4. Embedding new Map Monkey
    By ildena in forum Road Runner
    Last Post: 01-31-2005, 04:31 AM
