Results 1 to 10 of 15
Thread: Think I foubd BUG with map monkey and media car
    Constant Bitrate cdevelasco's Avatar
    Dec 2004
    Miami, FL / Caracas, Venezuela
    Hello, everything works fine with ver 1.1.3 except for this one thing. I have map monkey running embbeded perfectly into Media car, (latest version ver 1.91 i think) any ways here is the problem i start map monkey by pressing the GPS button. run it fine, do whatever I want etc. I must add that I also updated with the latest executable file that is supposed to fix the advanced GPS problem and closeing with the x button. Anyway now when I press the X in Media car to exit, it exits fine, but when I return to Map Monkey by pressing the GPS button again I get this error message below. This used to never happen before with other versions of map monkey, all the way upto beta 3 release I never had this problem. I can't remember if the original executable of ver 1.1.3 did this, I only have the updated one now. NM PLEASE HELP!
    FLAC mauri's Avatar
    Jan 2004
    You have update the MAP MONKEY.exe whit the new hotfix posted by Ninja?
    Download this,fixed the problem.
    Mauri
    Dec 2004
    As I mentioned in pmy post I already updated the file with the fix. I works fine when I run it by itself, but not when I run it within media car
    Dec 2004
    Also get this error message
    hello have more to add to my problem, I for the most part, get the error number 5 above, but once in a while I get error 91.
    Error Details:
    Number: 91
    Description: Object variable or With block variable not set
    Source: Unload_Destinator
    Version: 1.1.344
    HelpContext: 1000091
    HelpFile:
    LastDllError: 0
    I have recreated the same problem both in my laptopn and in my carputer, I can go into GPS in media car, use it, press the x button, to exit, and then press the GPS button to go back in to map monkey, once in a while it goes back in with no problem, but very rarely, 99% of the time I get that error no 5, and very few time error 91. I I press ctrl alt delete to go to the task manager, and I notice that the sapi plugin is still loaded even though I pressed the x in media car, and also nce in a while the maponkey.exe is still in the taskbar even after pressing the x, once I terminate these manually, I can the go back to media car and press the gps button, and it goes into map monkey fine, then I exit, tryh again, and get the same error. any ideas?
    Maximum Bitrate wizz's Avatar
    Nov 2004
    Leicestershire UK
    I think you will find that Map Monkey is still running.
    Try Ctrl/Alt/Delete for Task Manager and check Applications
    You have got to come out via Menu/Exit
    Wizz
    Car : Ford Focus Zetec 1.6
    Carpc :Lin-ITX Plus 7" touchscreen/Toad 8" roof screen
    Morex 3688 case/M2-ATX PSU/Commell V-672 P4 3.2Ghz/1024DDR2/40GB 2.5" SATA HDD/Sony DVD/CDRW
    BU303 GPS/Mercury 11b WiFi/Parking Sensors
    Colour I/R Reversing Camera
    Dec 2004
    Exactly, MapMonkey.exe is still running, as I explained in my post above with the second error message. It works fine when I exit via the exit button, but then I have to also press the x button in media car to go back to the media car main page. Kinda sucks. Wish I could get all the functionality like i had before with other mapmonkey versions, just simply press the x button in media car and it correctly exits mapmonkey, and this way I dont' have to do the "double exit" technique. any chance you can fix this NM?
    thanks
    Dec 2004
    Request for possible fix?
    OK Sorry to post so much but I've been experimenting. Luckily I saved the First installation file of the ver 1.1.3 official release (the one sans the fix for advanced GPS and the so called x button to exit not working fix) I erased all my installation and re installed this original file. Now it works PERFECTLY!, so I think i've narrowed the problem being to whatever it was NM changed to "fix" the x button problem, now created a problem in my computer and it won't exit correctly using Media car, HOwever like I said ,before the fix, the original installation file allows me to exit perfectly out of map monkey and then back in as many times as I want through media car. WHile with the "new" installation file with the fix, doesn't allow me to go back into map monkey after I exit using the x button in media car. So now atleast I have it working how I like it, but the problem now is that I don't have the advanced GPS fix. I am hoping this following request I am going to do it possible. SO Ninja Monkey, would it be possible for you to create an executable file, that includes the advanced GPS fix, but doesn't have any of the changes or updates that you did to the exit scheme. meaning basically can you provide me with an executable file that is just like the original one provided in the very first official ver 1.1.3 release except add the advanced GPS fix to it and thats it, don't add any x button fix? i would GREATLY appreciate it.
    thanks,
    Carlos
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    my brain just melted!
    I'd rather fix it for everyone than have a seperate version just for you...I'll see what I can do
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
    Dec 2004
    Great! thanks NM, I hope you can find a general solution to the problem. If you need any more info from me just let me know. THanks again for all the help. I'll keep this one nice and short to avoid any brain melting.
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Quote Originally Posted by Ninja Monkey
    Is this done ? Noticed the installer is updated...
    Terran
  1. RELEASE: Map Monkey v1.1.3
    By Ninja Monkey in forum Map Monkey
    Last Post: 02-12-2009, 11:27 AM
  2. Map Monkey v1.1.3 BETA 3
    Last Post: 03-29-2005, 09:50 AM
  3. Replies: 3
    Last Post: 02-03-2005, 01:11 PM
  4. Embedding new Map Monkey
    By ildena in forum Road Runner
    Last Post: 01-31-2005, 05:31 AM
