Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: Random PC freezing ONLY when Map Monkey 1.1.3 is running
  1. #21
    Maximum Bitrate Chita79's Avatar
    Oct 2004
    San Diego, CA
    got some more info on this freezing issue.... it freezes with FreeDrive on for a while too... which now leads me to believe that its something in the core of the code of D3. MM and FreeDrive are both derived from the same code, so now what im gonna try is to leave just the CarPC running with RR running for a day or 2. If it doesnt freeze, then its 99% a D3 issue, and i might have to format the PC and start fresh, cause i dont know what the software conflict could be at this point. (its probably way beyond me)
    '05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
  2. #22
    Jan 2004
    Jersey/NY
    Sorry to hear this... keep us updated Chita... I have no updates on my end... I haven't even used the carputer in the longest time.. been too busy
  3. #23
    Aug 2004
    Germany
    I have the same problem. When I installed MapMonkey and it freezed 2 or 3 times I installed FreeDrive. Two days later this freezes also. I also thought about D3-SDK being the cause. The CarPC does NOT crash when MapMonkey and FreeDrive are not running.
    This happens on my HomePC and CarPC. I don't think that reinstalling the system helps. Although my HomePC isn't that clean, the CarPC is. I just installed required software. Didn't experiment. Didn't install any OS-Optimizations. I'm somehow sure that it's D3-SDK (it can't be the launcher which I have to use for FrodoPlayer, can it?)
  4. #24
    Variable Bitrate euro320i's Avatar
    Apr 2003
    Near Frankfurt
    I am also running the latest Mapmonkey, the PC does not freeze, MAPMONKEY looses contact with the GPS. The cute little blue arrow that shows the direction you are driving turns into a red 'x' after about 10 minutes. The rest of the PC runs fine, I can minimize Mapmonkey and run winpamp normally. I re-installed MM several times, but still the same happens. I think it may have to do with the USB bus I suspect. When I re-start MM I get contact again for a few minutes b4 I loose the GPS again.
    o/______\o
    (oo_OO_oo)
    []o-----------o[]
    '94 320i
  1. How2 control CarPC from key fob....
    By NotchbackVW in forum Power Supplies
    Last Post: 09-21-2007, 05:27 PM
  2. Map Monkey final - release data?
    By alanp in forum Map Monkey
    Last Post: 01-27-2005, 05:43 PM
  3. Pc keeps freezing and powering off
    By lindleyalex in forum General Hardware Discussion
    Last Post: 12-24-2004, 06:46 AM
  4. GTI PC Up and Running!!
    By Nanozic in forum Show off your project
    Last Post: 07-20-2004, 11:10 PM
  5. freeway driving with PC running, success
    By cproaudio in forum General MP3Car Discussion
    Last Post: 09-24-2003, 10:59 PM
