Results 1 to 9 of 9
Thread: Can't Select GPS Com Port !!
    Oct 2004
    I just installed Map Monkey official, and everything looks great...
    ...but
    I configure my GPS to Com5 in Advanced GPS settings (which is where my
    gm-210 is confirmed to be located), but in the GPS status page,
    it shows Com3.
    Com3 is the only item in the Drop-down for Port, so I can't change it there.
    Any suggestions?
    Thanks in advance.
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Quote Originally Posted by buckle
    ...but
    it shows Com3.
    Any suggestions?
    Thanks in advance.
    You don't need to select it in *both* places. If you've selected advanced GPS and put the com port in there then that's enough.
    Oct 2004
    Ok, I selected it in Advanced GPS settings...Map Monkey can't find it. GPS status page still shows only Com3.
    So I decided to change the port for the usb GPS to com3 in device manager.
    Change Advanced GPS settings to com3 etc. -> MM still can't see it.
    the GPS Status app that came with the GM-210 scans all ports to find the GPS and
    successfully finds it on Com3. (It takes two scans to find it.)
    It may or may not be relevent, but, I seem to have fried my serial port recently so
    I had to move my serial touchpad over to the ps/2 mouse port.(using mfg. supplied adapter)
    Anyway, Still not working...Thoughts?
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    If you are using Avanced mode IGNORE gps status! With advanced mode Map Monkey takes control of the GPS and the D3 SDK won't be connecting (and so GPS status will be wrong)
    I'm guessing the reason it's not working is due to the wrong protocol or baud rate selected. Get SiRFDemo or some other GPS diagnostic app and see if that can connect (or even hyperterminal)
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
    Oct 2004
    The Receiver came with it's own diag. app and it finds it. I used the same settings (NMEA, 4800) that the diag app used.
    I will try another diagnostic app to see if there are any problems with it.
    Newbie Aircargoservice's Avatar
    Jan 2005
    Denmark
    When i am running Destinator it finds my gps, but when i want to "set" gps it say "com port busy" - any idea?
    Can u tell me the windows name for mapmonkey?
    airCARgoservice
    Oct 2003
    Madrid
    Quote Originally Posted by Aircargoservice
    Yes, if you have advanced option turned on, then ignore the Destinator gps settings.
    'windows name' You mean what it says in the titlebar?
    Jan 2005
    Denmark
    I am using Centrafuse and i need in order to run Map Monkey, to type the "windows name" btw thx, for tip with the gps.
    airCARgoservice
    Oct 2003
    Madrid
    I think you need to look at this post - Map Monkey Launchers (Fixes for Frodoplayer, Centrafuse, Mediacar...)
  1. Question on Garmin 16 GPS receiver
    By cproaudio in forum GPS
    Last Post: 05-23-2008, 02:32 AM
  2. Replies: 16
    Last Post: 09-05-2007, 05:19 PM
  3. USB Serial Port Adapter Troubles
    By bLindmOnkey in forum General MP3Car Discussion
    Last Post: 10-14-2004, 12:29 AM
  4. a new way of GPS
    By brownpage in forum GPS
    Last Post: 08-24-2004, 03:51 PM
