Results 1 to 4 of 4
Thread: MonkeyTalk.dll :: IsMapMonkeyRunning always returns false
    UHF
    UHF is offline
    Jan 2005
    Just summarising my findings from today in a meaningful error report.
    I have updated my code to the new MapMonkey method names from code which previously used d3talk.dll and noticed that in the newer DLL, it always returns false even if mapmonkey is indeed running.
    I've tried assuming its running but then you just cant communicate with it anyway. I get the feeling the new dll just cant find the app loaded as its got a different name or something else really easy to fix
    Even running Ninja's own sample vb app, it refuses to embed, my code is running a variation of this theme and naturally also fails.
    Any workarounds or is there something license related going on here, I might be wrong but I thought that was only to do with the D3 SDK licence, monkey talk is all home brewed is it not?
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    Somethings up with your installation, the test app works fine here...and I know of quite a few people who have had success with the DLL.
    Try registering it again, and make sure "Plugin Support" is enabled in Map Monkey configuration (It's disabled by default)
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
    UHF
    UHF is offline
    Jan 2005
    I have tried reinstalling and registering it lots.
    However I didnt know that plugin support had to be enabled, I will try this, many thanks.
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by Ninja Monkey
    I had that problem too. Plugin support solved it for me
