Error No.: -2147221187
Hello, I've posted this error in another thread, however along with some other questions (which were already answered.. thank you very much!) I'm posting this error now separately in hopes that someone recognized it and can provide me with some help.
The situation is the following. I have Map monkey running embedded in Road Runner, I turn of the car and it goes into hibernate. When I turn the car back on OS goes back into Road runner which was running MM embedded, however I get the following error
Error Details
Description: Could Not open Comm Port!
Source: Re-Connect_GPS
Ver 1.1.344
Help Context 1000440
Just to let you know I originally had it set up in adv GPS, sirf, com 3, 38400, I then switched it to (adv GPS) NMEA, com 3 , 4800 and still get the same error, I have to exit the gps program and re -enter it and then all works well. (offcourse I have the recconect GPS option marked) any ideas? I would greatly appreciate it.
thanks,
Most likely related to the IGuidance/Routis issue that some people experiance after Hibernating. With IGuidance/Routis you have to disconnect the GPS connection and then reconnect.
Installed.
-GPSSecure- - GPS Tracking
physically disconnect the USB connection you mean? if I exit map monkey and enter again after getting this error, all works fine. Anyways, many people have it working after hibernation, i wonder if i'm the only one....
Map Monkey Creator
I think map monkey is trying to reconnect before your USB devices have been (re)detected...in the few seconds between closing and restarting the app windows has probably initiated the com port again.
I'll add an optional delay before map monkey will try and reconnect, expect a hotfix soon
any updates on the hot fix?
Map Monkey Creator
not even started it yet
it'll probably be the weekend, providing i have some free time
Sounds good. no pressure man
take all the time you want....I was just curious about the status..cheers
Map Monkey Creator
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
