Nobody can help???
Is there something I could do to fix it?
With version 1.1.3 I get after some seconds of MM running or maybe minutes the close message box that (if it set to) it tells you to send or not to send a report!!
I have advanced GPS on and I get sat lock..![]()
Nobody can help???
I'd check for memory/processor issues if you're the only one getting it.. I never had a MM error like that (unless I run it more than once )
Ride Runner RR's Myspace
you have to give a little more info than that. What does the message box say. Does it have a details button?
I have attached the file with the details I get!!!
I get this error both in desktop PC and CarPC..
I've noticed that if I have enabled in the settings.ini to communicate with custom apps it will take tolnger to freeze![]()
I only get this error when I have advanced GPS enabled... Could it be something with BT GPS receiver? It is the navman 2100!!
