Results 1 to 3 of 3
Thread: OSK Kills RR
    Feb 2004
    OSK Kills RR
    Hi Ninja, Hi Guys,
    I am working on a fully integrated MM in RR. (I told this so many times, everybody knows It. )
    when I open the Osk of MM in the normal navigation-Window, it kills RR.
    I dont know why, but I get a 100% Cpu-Usage and thats it.
    I know there is no sense to get the Osk in the Navigation window, but I know no way to hide It when Navigation is active, so it is there everytime.
    Thank you.
    Constant Bitrate ruairi's Avatar
    Jan 2005
    OSK can be turn off by default and then toggle it when needed.
    In MM settings.ini in the Global section set
    An then have a button in RR to toggle the OSK on and off, the button command would look like:
    I'm using RR & MM embedded and this is working fine.
    Feb 2004
    Thank you for your answer.
    But, I ment that the Osk-Button is there anytime, so when someone press is in the main navigation window the system hangs up.
  1. I-BUS sterring buttons now working for RR
    By CdRsKuLL in forum Road Runner
    Last Post: 06-19-2007, 08:13 PM
  2. RR 03-06-05 - Radio Preview ...
    By guino in forum Road Runner
    Last Post: 07-04-2005, 01:58 PM
  3. RR 3-30-05 ... Mappoint ...
    Last Post: 04-06-2005, 12:47 AM
  4. girder on RR
    By mick0uziel in forum Road Runner
    Last Post: 03-29-2005, 07:00 PM
  5. RR 03-16-05... Few things..
    Last Post: 03-17-2005, 01:00 AM
