Results 1 to 10 of 14
Thread: "drive carefully" and then no more notifications...
    Apr 2005
    Hi,
    after starting the navigation ("drive carfully") there are no more instrucions.
    I miss the voice instructions i. e."turn right" or so...
    also, when i'm leaving the route, nothing happens!
    Please help me!!
    Thanks a lot!!
    celeron 566, 256 MB
    intel chipset 810
    WIN XP
    Jul 2004
    NL, Druten
    Alert settings - signs visual notification should give you verbal and visual notification.
    works with me (and the rest of us:P )
    Apr 2005
    I set this option... no change at all.
    also there is no automatic recalculation when i get off the route...
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    Make sure you don't have the voice pack set to "Notifications Only"
    The route recalculation won't happen straight away, it takes a few hundred yards before it decides you're definitely off course (and it's not just a positioning error)
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
    Apr 2005
    thanks for your reply!
    But I tried now nearly everything... without any success
    Your software looks so great, but it didn't navigate me! What did i wrong??
    The map moves when i drive and shows my position, so far so good.
    But when i have to turn right there is no arrow or sth like that on the screen, or a verbal notification. Even if I'm Miles away from the route, there is no recalculation.
    Please Help me!!
    Low Bitrate Mcnovy's Avatar
    Feb 2005
    Denmark
    try un-install and install again.!
    just for the kicks.!
    Sorry for the english
    CarPC Specs.
    Via Epia MII 12000 \\ 512 Mb Ram \\ 200 GB Western Digital \\ PCmcia asus wi-fi
    Xenarc 7" Touchscreen \\ Usb Bluetooth \\ Carnetix P-1280
    Raw Wave
    Jun 2004
    On the beach
    Are you sure you are in navigation mode?? Not sure if that makes any difference or not but worth a shot.
    Raw Wave tj!2k4's Avatar
    Oct 2004
    Is the GPS working properly? Check the satellite status...
    Nov 2004
    St Louis
    Quote Originally Posted by kranze
    O.K. Now I'm having the same problem. Have reinstalled three times, but no directions, no recalculating route, everything else works fine. HELP!
    Mar 2005
    UK
    in the front end eg. road runner you can set the volume to hear the directions. change this
