Results 1 to 8 of 8
Thread: No sat count and "not Implemented"
    Vik
    Vik is offline
    Newbie Vik's Avatar
    Nov 2004
    Belgium
    Hey Ninja Monkey,
    I'm using MapMonkey quite some time now without any bugs.
    But unfortunately I have one now,
    when starting the application, it gives following error:
    Error Details:
    Number: 429
    Description: Invalid GPS Settings! (ActiveX component can't create object)
    Source: Connect_AdvGPS
    Version: 1.1.348
    HelpContext: 1000429
    HelpFile:
    LastDllError: 0
    After pressing ok the app works fine except for the speed indicator, which shows "Not Implemented" , and the satcount remains at zero.
    Do you have any solution for this?
    Thanx
    Vik
    Newbie abojad's Avatar
    Aug 2005
    Question Had the Same Problem two days ago
    all the sudden MM errors, click OK, then gps works, and screen says "not Implemented'
    HELP
    Aug 2005
    Just Reinstall MM, will fix the problem
    good luch
    Vik
    Vik is offline
    Newbie Vik's Avatar
    Nov 2004
    Belgium
    I've Performed a format C: and reinstalled all the software again (this was neccesary anyways) Previous errors are now solved but when starting MM it always begins in the config window. after that it loads normally but now it gives the error:
    Error Details:
    Number: 53
    Description: File not found
    Source: Load_ClickPositions
    Version: 1.1.348
    HelpContext: 1000053
    HelpFile:
    LastDllError: 0
    Everythings works just fine for the rest.
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    Hmm, im not sure you've installed it correctly...or perhaps only installed an upgrade rather than the full version and then the upgrade on top.
    Either way you're missing a file called "clk.pos". You'll need this for a lot of the menus to work correctly.
    Edit: just noticed you're also always starting with the config. This will show if there are missing settings from your settings.ini, I would definitely try re-installing the full version
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
    Vik
    Vik is offline
    Newbie Vik's Avatar
    Nov 2004
    Belgium
    I'll try this as soon as I get the time..
    Thanx....
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    just had this problem as well as hotkeys and some other gps error, after I reinstalled windows.
    just delete the directorys and reinstall the app.
