Sounds like you have the wrong destdll file, if it used to work try registering it again (regsvr32 c:\destinatorapps\destinator\destdll.dll)
Map Monkey 1.1.3 was running fine and suddenly the following errors start happening:
What is going on?
ERROR WHEN STARTING APPLICATION:
Error Details:
Number: 458
Description: Variable uses an Automation type not supported in Visual Basic
Source: Create_Destinator
Version: 1.1.348
HelpContext: 1000458
HelpFile:
LastDllError: 0
ERROR INMEDIATELY MAPMONKEY SCREEN IS SHOWN:
Error Details:
Number: 91
Description: Object variable or With block variable not set
Source: Embed_Destinator
Version: 1.1.348
HelpContext: 1000091
HelpFile:
LastDllError: 0
ERROR WHEN "CLICK" ON MENU TAB:
Error Details:
Number: 91
Description: Object variable or With block variable not set (D3Request|Home)
Source: p_Command
Version: 1.1.348
HelpFile:
LastDllError: 0
ERROR WHEN EXITING MAPMONKEY:
Error Details:
Number: 91
Source: Unload_Destinator
Version: 1.1.348
HelpFile:
LastDllError: 0
Destinator 3 For PC! - http://www.map-monkey.co.uk/
