Hi all, I found that when I put my home coordenates in MM config itīs unable to locate an adress. Going into .ini file I found that lat. and long. coordenates are changed one by other, I fixed it in .ini file and it works. Other thing Iīm experimenting with MM is when I launch it (with or without RR), it waits 30-50 segs. till starts, even config starting. Any solution? Thanks.
