Error -2147024770 and Error 91 inside RR
When I launch MM from inside roadrunner, I initially get error number -2147024770, which states:
Number: -2147024770
Description: Automation error
The specified module could not be found.
Source: Create_Destinator
Version: 1.1.344
HelpContext: 1000440
HelpFile:
LastDllError: 0
and then whenever I try to do anything after I discard the error, I get error 91, which states:
Number: 91
Description: Object variable or With block variable not set
Source: Embed_Destinator
Version: 1.1.344
HelpContext: 1000091
HelpFile:
LastDllError: 0
I have tried reinstalling, made sure I had the VBS files, and everything else. When I launch the MapMonkey.exe file, I get an error, but it still functions after I discard it. I don't understand why it would work outside RR, but not when I embed it.
Thank You,
Elliot
bump I still can't get this to work. Please help!
zomg please help, or i'll have to keep bumping this thread.
I've got the same kinda error 91 Object variable or With block variable not set.It appears from time to time.Also I got the com port in use despite the fact that the port is not use.if I start MM as a stand alone application I dot get those errors but only when I start from within road runner.Anyone got the fix for that?
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
