Results 21 to 30 of 37
Thread: On line my skin for Map Monkey update whit the volume control
  1. #21
    FLAC mauri's Avatar
    Jan 2004
    Quote Originally Posted by vintageb3
    Done this Wizz...still get the smaller OSK...will look at it again when I have more time...thanks!
    vintageb3
    Delete all my old folder with the old skin.
    Unzip my file,put my new skin in Map Monkey Skins folder.
    Replace the file "skin.ini" downloaded in my new skin folder(correct the small problem with this).
    Open the MM Config utility,skin, select my new skin.
    Confirm,Map Monkey reopen with my skin new and big OSK.
    Simple!
    Mauri
  2. #22
    Maximum Bitrate wizz's Avatar
    Nov 2004
    Leicestershire UK
    vintageb3
    You MUST run Map Monkey config and sellect NEW skin.
    Wizz
    Car : Ford Focus Zetec 1.6
    Carpc :Lin-ITX Plus 7" touchscreen/Toad 8" roof screen
    Morex 3688 case/M2-ATX PSU/Commell V-672 P4 3.2Ghz/1024DDR2/40GB 2.5" SATA HDD/Sony DVD/CDRW
    BU303 GPS/Mercury 11b WiFi/Parking Sensors
    Colour I/R Reversing Camera
  3. #23
    Variable Bitrate fly_dutchie's Avatar
    Feb 2004
    Amsterdam
    Hi Mauri,
    I use your new skin, it's great, thanks.
    small problem:
    the zoom bar button does not show the white arrow for up and down
    see:
    "It does not understand, if it does not ride."
    M10000, 512 Mb, 2,5" 40G, Slim DVD, Opus 90W, Xenarc 7", Leadtek 9532 GPS,
    RoadRunner, MapMonkey, Pioneer HU, Pioneer 4 ch 400W, Kappa 6.5, Basslink X 200W
  4. #24
    Feb 2004
    Amsterdam
    Also maybe for future
    this font better (for screen)
    or Tahoma/Arial
    The font for menu in your 1.3 skin is for newspaper and books.
    Thanks Michael
    (I like your skin the best of all, still )
  5. #25
    FLAC mauri's Avatar
    Jan 2004
    Quote Originally Posted by fly_dutchie
    Hi Mauri,
    small problem:
    see:
    Use my Destinator.bmp file?
    You have replace ALL file original of Destinator to my file placed in my sub-folder/skin?
    You have change something in Destinator.ini?
    Mauri
  6. #26
    Feb 2004
    Amsterdam
    Quote Originally Posted by mauri
    Mauri
    2. What do you mean with ALL file original of Destinator?
    3. No
    It looks like something to do with tiling of background image? I can see the arrows very dark.
    Michael
  7. #27
    FLAC mauri's Avatar
    Jan 2004
    In the folder of my skin,there and a sub-folder.
    Open her, copy and replace the 4 files to inside in C:\DestinatorApps\Destinator\Common\Interface\Visu al\All, replacing them with the 4 original.
    Then test if ok.
    Edit: the sub-folder you have to leave inside my skin, remembers.
    Mauri
  8. #28
    Constant Bitrate vintageb3's Avatar
    Nov 2004
    Scotland
    Quote Originally Posted by wizz
    Wizz
    THIS is what I have been doing...
    The only bit I don't get is replacing the skin.ini...where do I replace that to?
    vintageb3
    M10000 mainboard,256 RAM, 80 Gig 3.5" drive, PWS-120-M, ITPS, Lilliput 7" touchscreen, XP Pro SP2, Frodoplayer, Map Monkey, InfoMap Navigator 4, WIFI
    Current: Bluetooth. Trying to get Phonecontrol to work with SE T610.
  9. #29
    FLAC mauri's Avatar
    Jan 2004
    Skin.ini has to remain where and now, inside the folder Mauri D3_2
    Mauri
  10. #30
    Feb 2004
    Amsterdam
    Thanks mauri,
    It all works now, just trying to get a better readability on the 'current location' and 'ETA'...
    Michael
  1. Replies: 0
    Last Post: 11-27-2004, 05:47 PM
  2. FM Radio- VOlume controls- Mute line-in- control master
    By live2themaxuk in forum FrodoPlayer
    Last Post: 11-16-2004, 02:33 AM
  3. Replies: 0
    Last Post: 11-04-2004, 05:46 PM
  4. Volume control question..
    By Kamakazie2 in forum Software & Software Development
    Last Post: 10-07-2004, 06:16 PM
  5. USB Sound Card with ASIO driver and volume control
    By tbdombrosky in forum General Hardware Discussion
    Last Post: 02-03-2003, 11:00 PM
