Results 1 to 4 of 4
Thread: Skinners Help, MM sugestion!
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    Question Skinners Help, MM sugestion!
    Any chance someone can produce a MM skin thats like Freedrive skin with the menu, buttons, and info on the left. This suits the widescreen better as it leaves more of the map visible when MM is embedded in a frontend like RR.
    FLAC NiN^_^NiN's Avatar
    Aug 2004
    Australia, Melbourne
    Why not just use freedrive? the speed cameras will be embedded soon and cdr is changing the skining system so you could make it work like MM if u wanted lol
    CarPC Status:
    GPS: 99%
    Hardware: 99%
    Software: 92%
    Case Install: 99.9%
    Dash Install: 100%
    Car Install: 72%
    Constant Bitrate ruairi's Avatar
    Jan 2005
    Spain
    Are you looking for something like this:
    Here there's no MM bar and I use RR to send menu commands to MM.
    Check out the RR skin Editor http://mp3car.com/vbulletin/showthre...ht=skin+editor to create your own skin. It's not difficult but it takes time!
    Nov 2004
    St Louis
    Check out Dena old Style, too.
  1. RR Menu to emulate MM Menu button
    By GizmoQ in forum Map Monkey
    Last Post: 09-05-2006, 02:02 PM
  2. Problems with MM Advanced Mode/SiRF
    By RoyN in forum Map Monkey
    Last Post: 04-24-2005, 11:49 AM
  3. Creating RR Skin For MM
    By studly_steve007 in forum Map Monkey
    Last Post: 04-14-2005, 01:20 PM
  4. SENDKEY & MM Embedding
    By ruairi in forum Road Runner
    Last Post: 04-04-2005, 04:36 PM
  5. Strange Bug in MM...
    By garo in forum Map Monkey
    Last Post: 03-02-2005, 06:49 PM
