Results 1 to 10 of 12
Thread: Moving the menu to the top
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Okay MM skinners, how do I move the menu bar currently on the bottom to the top where the info bar is? Do I have to create a completely new skin or I can modify existing skin to do that?
    Why you may ask? I am running embeded with Road Runner and RR skin already has button and stuff on the bottom of the screen. I don't want to have 2 bars on the bottom when the top has none.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Constant Bitrate ruairi's Avatar
    Jan 2005
    Spain
    Why not rip out the MM menu bar completely and create a new RR menu layout?
    Much like I've done for my skin:
    Here there's no MM bar and I use RR to send menu commands to MM.
    Check out the RR skin Editor http://mp3car.com/vbulletin/showthre...ht=skin+editor to create your own skin. It's not difficult but it takes time!
    Sep 2003
    Beach City, Socal
    That's cool, I have to take a look at that. Thanks
    Sep 2003
    Beach City, Socal
    I try some MM command in RR but they don't work.
    The only one that work but baddly is the Zoom function. It doesn't zoom like the + and - on the actual MM skin.
    "MM;Menu" doesn't work and so the Hotkey_CMD stuff.
    Jan 2005
    Spain
    Make sure you have plugins on and port 9913 listening in the settings file.
    Apr 2005
    Quote Originally Posted by ruairi
    Where can i get that skin of yours ?
    Jan 2005
    Spain
    Check this thread
    It uses RR for the buttons & MM for the Map stuff. There are many RR skins that do similar stuff, check the RR Skins board if you want to see others.
    May 2005
    Germany
    Hello,
    how can I hide the bar above the menu bar? Itīs the bar with the GPS-Signal in the right corner!
    Can I hide the zomm-bar, too? How?
    Ti-
    May 2005
    Germany
    Have nobody an idea?
    Ti-
    Jan 2005
    Spain
    Quote Originally Posted by Ti-ejtsch
    Hello,
    Ti-
    First I would suggest you keep a backup copy of settings.ini and Destinator.inf files that you'll change.
    Hide GPS signal bar: open "C:\DestinatorApps\Map Monkey\settings.ini" and in the [Global] section edit this line so it has this value:
    HeightOffset=35
    To get rid of the Vertical Zoom Bar go to this file:
    "C:\DestinatorApps\Destinator\Common\Interface\Vis ual\All\Destinator.inf"
    And find the lines that start with the following and change the values so it is the same as below:
    ::P,SLIDER,1,1,1,1,1,1
    ::P,BAR_SLIDER,1,1,1,1,1,1
    ::P,ZOOM_IN,1,1,1,1,1,1
    ::P,ZOOM_OUT,1,1,1,1,1,1
    I leave a 1 pixel scrollbar just for fun, but it is not very visable
  1. RR Menu to emulate MM Menu button
    By GizmoQ in forum Map Monkey
    Last Post: 09-05-2006, 02:02 PM
  2. Menu always on top, other new features
    By clean customs in forum FrodoPlayer
    Last Post: 01-22-2005, 04:27 PM
  3. skinning --> full screen menu
    By djScript in forum FrodoPlayer
    Last Post: 11-08-2004, 07:14 PM
  4. FS: SF Bay Area: Optima Yellow Top
    By VanMan69 in forum Classified Archive
    Last Post: 08-19-2004, 03:17 PM
  5. MediaCar Skin Sneak Preview
    By mindtool in forum MediaCar
    Last Post: 11-21-2003, 04:14 PM
