If I select an artist by searching using the osk, it begins playing the selected song. When that song's over it goes to the next, but does not update the display (currently playing song). The way to get it to update is to hit the next button, then it updates properly
Ben S. Stahlhood II
Hybrid Mobile
MMC/Transcend Developer
http://www.hybrid-mobile.com/
http://www.cocoamachine.com/
http://weblogs.asp.net/bstahlhood/
Another issue is mp3. I have over 3000 mp3 and when it load up it get stuck on all music. IT hangs for awhile and then it start moving. This happen everytime u go to all music.
Ben S. Stahlhood II
Hybrid Mobile
I'm also having problems with ID3 tags. I've tried several versions and cant seem to find one that works reliably. I've been converting them using iTunes. If I used a simple tag editor it seems to work, but I dont want to edit 3000+ by hand. Thanks
The Webcam facilty does not have the "mirror image" function. Hope that it could also have an option to record.
Anyway, can't wait to install the next release. Keep up the good work.![]()
This happens when I try to open pictures
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at MobileMediaCenter.MmcForm.photoListBox_MouseUp(Obj ect sender, PInputEventArgs e)
at UMD.HCIL.Piccolo.PNode.HandleEvent(PInputEventArgs e, PInputEventHandler handler)
at UMD.HCIL.Piccolo.PNode.OnMouseUp(PInputEventArgs e)
at HybridMobile.Controls.MmcListBox.OnMouseUp(PInputE ventArgs e)
at UMD.HCIL.Piccolo.Event.PInputEventArgs.DispatchTo( Object sender)
at UMD.HCIL.Piccolo.Util.PPickPath.ProcessEvent(PInpu tEventArgs e)
at UMD.HCIL.Piccolo.PInputManager.DispatchToPath(PInp utEventArgs e, PInputType type, PPickPath path)
at UMD.HCIL.Piccolo.PInputManager.Dispatch(PInputEven tArgs e)
at UMD.HCIL.Piccolo.PInputManager.ProcessInput()
at UMD.HCIL.Piccolo.PRoot.ProcessInputs()
at UMD.HCIL.Piccolo.PInputManager.ProcessEventFromCam era(EventArgs e, PInputType type, PCamera camera, PCanvas canvas)
at UMD.HCIL.Piccolo.PCanvas.OnMouseUp(MouseEventArgs e)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Messa ge& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message & m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.42 (RTM.050727-4200)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
MobileMediaCenter
Assembly Version: 0.8.1000.7
Win32 Version: 0.8.1000.7
CodeBase: file:///C:/Program%20Files/Hybrid%20Mobile%20Technologies/Mobile%20Media%20Center/MobileMediaCenter.exe
HybridMobile.Membranes
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files/Hybrid%20Mobile%20Technologies/Mobile%20Media%20Center/HybridMobile.Membranes.DLL
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Intellified
Assembly Version: 1.0.2515.39325
Win32 Version: 1.0.2515.39325
CodeBase: file:///C:/Program%20Files/Hybrid%20Mobile%20Technologies/Mobile%20Media%20Center/Intellified.DLL
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
CodeBase: file:///C:/Program%20Files/Hybrid%20Mobile%20Technologies/Mobile%20Media%20Center/HybridMobile.Controls.DLL
HybridMobile.Media
Assembly Version: 1.0.2515.39326
Win32 Version: 1.0.2515.39326
CodeBase: file:///C:/Program%20Files/Hybrid%20Mobile%20Technologies/Mobile%20Media%20Center/HybridMobile.Media.DLL
Transcend.Translucent
Assembly Version: 1.0.2452.42065
Win32 Version: 1.0.2452.42065
CodeBase: file:///C:/Program%20Files/Hybrid%20Mobile%20Technologies/Mobile%20Media%20Center/Transcend.Translucent.DLL
Hybrid.Xm
CodeBase: file:///C:/Program%20Files/Hybrid%20Mobile%20Technologies/Mobile%20Media%20Center/Hybrid.Xm.DLL
Transcend.Translucent.X
CodeBase: file:///C:/Program%20Files/Hybrid%20Mobile%20Technologies/Mobile%20Media%20Center/Transcend.Translucent.X.DLL
HybridMobile.DirectX.DirectShow
CodeBase: file:///C:/Program%20Files/Hybrid%20Mobile%20Technologies/Mobile%20Media%20Center/HybridMobile.DirectX.DirectShow.DLL
System.Data
CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
AxInterop.ShockwaveFlashObjects
CodeBase: file:///C:/Program%20Files/Hybrid%20Mobile%20Technologies/Mobile%20Media%20Center/AxInterop.ShockwaveFlashObjects.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Getting the same as above? Pops up after a few when doing anything?
Besides that I like it....
at MobileMediaCenter.MmcForm.ProcessAudioMessages(Obj ect sender, String message)
at MobileMediaCenter.MmcForm.buttonPanel_MouseUp(Obje ct sender, PInputEventArgs e)
mscorlib
MobileMediaCenter
System
System.Drawing
Intellified
System.Xml
HybridMobile.Media
Hybrid.Xm
System.Data
enabled.
For example:
<configuration>
</configuration>
