Results 1 to 9 of 9
Thread: Problems after changing UMPC.exe to Iguidance.exe
    Sep 2006
    Houston, Texas
    First of all I would like to thank Red for the frontend software. I have been using the beta version 3 since October, and I have found it to be very easy to use with very few problems. I have one problem in particular I would like to address. When I run Iguidance v3.0 normally without any modification, I could easily use the "save the current location" option. However, when I change UMPC.exe to Iguidance.exe so that it will embedded into the frontend I can not. I would touch at the area around the speed, ETA, etc. and a window will pop up about the current location, but when i try to save the current location, it won't save.
    Also, after looking at the mp3car HD radio demo, would you Red consider maybe in the future to make a skin for that in your next version release? Considering it probably be after your next version, maybe a future add-on?
    I will appreciate any advice or suggestion to my problem.
    May 2005
    Mother Earth
    I will try and give you a method I use.
    When i use umpc I noticed i couldnt see the weather any anymore in IG3.0 or 3.0.1. The reason is 3d mode has alot of options greyed out
    If you have not done so switch to 2d mode.. Then press and hold the touch screen "like a right click" you should get a popup menu that has save location, weather, and a few other options.
    Wow red you going to be very busy if your commercial version finds out about hd radio..
    the silabs tuner is being a pain for you right now.. I canonly imagine hd coding.
    KIAs can have car pcs too..
    Mobile Impact Creator reddeath30's Avatar
    Mar 2005
    Fontana, California
    Amen Brother!
    Mobile Impact
    Highly innovative car computer multimedia/entertainment system software.
    http://mobileimpact.biz.tm
    Sep 2006
    Houston, Texas
    Thanks Nigwhyrito, I think that did the trick.
    Sep 2006
    Houston, Texas
    It also turns out that there is a patch Iguidance v3.01 on their website that fixes several of bugs which this is one of them.
    Just in case for people who haven't had the chance to look at the patch:
    Changes included in patch v3.0.1:
    On PPC, Laptop, & UMPC/Car PC:
    Fixed missing street # range in night mode
    Fixed 2D stopover feature dialog
    Fixed bug in itinerary & Detour
    Fixed certain address not geo-codeable
    Fixed routing problem through intersection internal links (incl. route from/to several Canadian provinces)
    Modified Guidance screen zoom switching distances
    Fixed issue with certain straight maneuvers towards freeway
    Fixed issue with approaching destination
    Modified 3D road width
    Changed code to go back directly to map screen for settings dialogs
    Added Immnext (next next maneuver) icon
    Added Panning mode exit timer (when routed)
    Added all state freeway shields
    Added shadow for dialog menu text
    Added code to retain Panning mode after routelist, current location dialogs
    On PPC only:
    Added timer reset code for PPC Phone edition
    Fixed Phone edition outputting slow voices
    Fixed distance unit display issue
    Improved bluetooth connectivity on wm5 devices running Broadcom bluetooth stack
    On Laptop only:
    Fixed routelist updating issue
    Fixed Current Location dialog
    On UMPC/Car PC only:
    Modified left/right arrow behavior
    Added COM port and BAUD rate dialogs in Settings screen
    Changed to default fullscreen
    There is also a second patch:
    iGuidance N. America v3.0(dvd version)/v3.0.1(cd version)patch file for map color/road width change
    If you prefer different map/road colors other than manufacturer's default setting, we are providing the following theme.ini files to enable some customization. Note: for 3D view, only colors may be changed but not road width.
    May 2005
    Mother Earth
    uh pccivic 25 are you sure that the patch fixes the save current location.
    I have the patch. I dont normally save location though. I just use the weather otpion in 2d mode.
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Explain this "weather" thing I have IG3 (not patch), can one access some kind of weather feature
    May 2005
    Mother Earth
    Quote Originally Posted by treetop777 View Post
    yep
    You have to have a internet connection.
    make sure your in 2d mode. it will not work in 3d mode.
    you will get current time, temperature a 5 day forecast and more from the weather channel
    if you have a keyboard hit W.
    if you have a touchscreen just hold you finger on the screen and a menu will appear.
    Sep 2006
    War-Town, GA.
    HOLY SH**!! There it is! I didn't know that! Thanks
  1. Replies: 33
    Last Post: 03-28-2008, 02:18 PM
  2. Problems with Touchscreen (Please help)
    By xdjneo in forum Power Supplies
    Last Post: 02-07-2007, 05:27 PM
  3. Replies: 4
    Last Post: 12-27-2006, 03:22 PM
  4. Hard drive shock problems.
    By Mikesz in forum General Hardware Discussion
    Last Post: 03-21-2005, 03:37 PM
  5. Xenarc and 800x480, and Changing Resolutiosn
    By Bobby_Aychamo in forum LCD/Display
    Last Post: 10-12-2002, 06:18 PM
