Page 8 of 10 FirstFirst 12345678910 LastLast
Results 71 to 80 of 92
Thread: Mobile Impact New Version 4.0a Beta Released
  1. #71
    Mobile Impact Creator reddeath30's Avatar
    Mar 2005
    Fontana, California
    Quote Originally Posted by nigwhyrito View Post
    I had that problem in version Mi version 3.. My fix was to hold my finger on the touch screen so the right click menu would come up.. Then you could either click exit full screen.. Or it would give the focus back to the window so you cold tap the screen again to toggle full screen, controls view or listing of songs view.
    Im wondering if the touch screen monitor/mouse program is causing this. I had an issue with the T-view monitors that would not allow the screen to go full at all because of the touch monitor/mouse software.
    Mobile Impact
    Highly innovative car computer multimedia/entertainment system software.
    http://mobileimpact.biz.tm
  2. #72
    May 2005
    Mother Earth
    No red I dont have a tv view or touch monitor software.. Its a xenarc 700tsv with the latest drivers at egalax. Want to know something else funny it only does it on certain media doesnt it do that on my whole collection just certain tracks.. course i am still using MI 3b in the car.
    Oh i i finally took some pics of me using it guess i go post that in the show off the ride forum..
    i am going to nstall 4.0c tonight and see if the same media is doing it.
    KIAs can have car pcs too..
  3. #73
    Dec 2006
    i tried the hold (rightclick) method, and it worked fine. doesn't happen all the time, seems to happen more often durring long periods of full-screen playback like dvds and watching tv episodes
  4. #74
    Mar 2005
    Fontana, California
    Quote Originally Posted by dj3stripes View Post
    I just took a trip from Michigan to California and I experienced the issue that you are referring to, like you said it doesnt happen all the time, so Im going to have to go line by line and see where it could possibly happen. Thanks again for all the help.
    Mobile Impact
  5. #75
    Maximum Bitrate tn6478's Avatar
    Jun 2006
    Houston, TX
    can you find a way to add the flv and mp4 extension into mobile impact. I dotn want to do an extension change to all my files. It screw alot of things up.
  6. #76
    Dec 2006
    how could it screw anything up? if it doesn't work, simply change them back to what they were before
  7. #77
    Jun 2006
    Houston, TX
    how you say. If you have over 4000 Music videos files and its in all different format its pretty annoying. You can change the file extension but sometimes its just not good. Also change them back aint a simple task if all my files are scatter in my folders. FLV files doesnt go into FLV folders and AVI files dont into there own folder if you know what I mean. I have my music sorted by favorite, Genre, etc.... Its just easier if you can add file extension and it will play.
  8. #78
    Dec 2006
    very true. but until the extensions are worked into a later version (i think red said not till at least 5, i could be wrong) it'd be a handy work around, and easy enough to test, if it plays in media player, simply change one of the said files' extensions. if it works, use a batch file renamer and you're set. i think it'd result in a quicker solution rather than waiting for the front end to be recoded
  9. #79
    Constant Bitrate Grimoire's Avatar
    May 2006
    Fayetteville, NC
    I love this front end and was waiting for IG3 to be usable, Is it usable in this version? Im trying to install Version 4.0c and I get hung up on registering fonts. It just hangs. But thats after I get the error:
    "The following file is in use and cannot be updated C:\Windows/System32\asycfilt.dll"
    Gives me a retry or cancel. If I cancel, setup resumes, but will hang when trying to register fonts. Any ideas? Hope I can get this running soon!
    [edit]Nevermind, Figured it out. I was installing IG3 and it was taking 1.5GB of RAM to do it. So things wernt running up to par....whoops.
    IG3 is working great inside 4.0c and Im EXTREAMLY happy so far. Though my screen resolution is 1027x768 is causing some problems, but I figure once I get it on 800x600 all will be solved. GREAT WORK RED!
  10. #80
    Mar 2005
    Fontana, California
    Quote Originally Posted by Grimoire View Post
    Thanks for the compliments. Its always nice to hear, great job, instead of this is broken, heh heh.... Yea, i basically built version 4.0c around the new iguidance version, then realized that i couldnt make everyone go out and buy it so i had to still support the older versions too. Im still planning on resolving some of the issues with shuffle and a few other things.
    Mobile Impact
  1. [frontend] Mmc Rc2 New Release 05.23.2007
    By Bitoholic in forum Mobile Media Center
    Last Post: 04-09-2008, 12:23 PM
