if you can play em in media player you can use this front end.
if you're having problems getting the files to show in your browser try adding .mp3 to the end. it was a work around in the previous release.
Are you able to add video format with this FE. I want to add FLV files and other files but i can't seem to find where to put it.
Yep. As long as you can play it in media play, just change the files extension. Instead of using mp3, I change them to avi or wmv. Makes it more easy for me to tell that it's a video file.
CAR:06 350Z | LCD:Xenarc 700TSV | PS:M2-ATX | CPU:2.0GHz Turion 64 | MB:GA-K8N51GMF | RAM:1GB PC3500 DDR | HDD:WD 250GB SATA | USB1:Zoom 140M WiFi | USB2:iOne Scorpius Keyboard | USB3:Logitech Wingman | SERIAL:GPS BR-355
that makes sense too, now that it's simply 'media' instead of 'audio' and 'video' for the interface
I have so many videos in flv format and mp4 that its just so hard to do. Can you add these extension to the next beta. Also I am unable to change skin. I change skin to the simp skin now i can't seem to change back.
Mobile Impact
Highly innovative car computer multimedia/entertainment system software.
http://mobileimpact.biz.tm
nah its not reading my mp4 files. I have alot of mp4 files like over 3000 of them and nothing shows. How hard would it be to just add the file extension to the .exe. having file support extension would be a plus.
perhaps this?
http://www.bluechillies.com/details/28681.html
it does a massive rename of files, so you could replace .mp4 with .mp3 and you'd be set. as long as they'll play in media player then you'll be golden
that might work. hmm how long does it take to rename all files. I hope it dont screw anything up though
Hi TN6478, I know this is not the answer you are looking for. It was stated earlier though to try different extensions.
First does the file play back in Windows media player... NOT media player classic.
Next some extensions appended to the end of some files will not work..
For example When i was playing with this method in the previous release..
I tried getting MI to see asf files in the audio module..well 2 extensions would work..
but i had to make sure the asf file was seekable.. I could only use .mp3 and .wav to make windows media player play it back
i tried .wma nope did not work with the .asf.
Also as of right now windows medial player does not have support to play back .flv on its own. Media player classic and ffdshow have the ability..
I had to recode all my .flvs to avi and add .asf to have all my videos in the audio module and extract the mp3 audio and remux it to the asf.
Also when i dont know if you tried or not but when you append a extension to a file for example myfile.flv.wmv you should try to open it in Windows media player first.. It should give a error message like are you sure you want to play this incorrect extension or format then there is a box to say dont ask me no more.. So try different extensions. .MP3 and .wmv will not work for all files. I have even used .wav on some of mine..
I have downloaded new version yet.. Too busy fixing other peoples pcs.
Cant wait though..
And if you did all i said then i do appologize for wasting your time by reading it.
have a nice day
there are some free flv converters out there that also convert in batch.
KIAs can have car pcs too..
