Results 1 to 10 of 13
Thread: IGUIDANCE 4 with MI
    Maximum Bitrate tn6478's Avatar
    Jun 2006
    Houston, TX
    IGUIDANCE 4 with MI
    I just tested it out on MI. Everything works great. I had to adjust the config setting for MI so the GPS look right from 583 to 550 but everything is good. All command still works. Only issue i am seeing is the new max button for IG4 that screw things up if u accidentally click on it.
    Mobile Impact Creator reddeath30's Avatar
    Mar 2005
    Placentia, California
    Quote Originally Posted by tn6478 View Post
    Very cool, thanks for working on that.
    Mobile Impact
    Highly innovative car computer multimedia/entertainment system software.
    http://mobileimpact.biz.tm
    Jun 2006
    Houston, TX
    Here is another question. Is there a way to mute or pause the Music when IG4 speaks. As of right now it just speak while the music is playing.
    Another thing is that I have the Silab USB radio when I turn it on it works but the problem is that if i switch back to Media. It does not mute and play with the media unless i go to the eq and lower the volume all the way down then it will stop.
    Also how can i save the channel for the radio within the program and not having to go to the preset.ini to do it.
    Mar 2005
    I ran into this issue in develpment, where when you exit the program it doesnt seem to save the last radio station that was playing on the FM radio, If you manually punch in the radio station from the number pad, then hit the change channel button, this will cause the station to be saved. Im not sure I understand your question, are you saying that when you go from the FM radio to the Media player the FM radio is still playing? Please clarify this for me. Thanks.
    Mobile Impact
    Jun 2006
    Houston, TX
    Quote Originally Posted by reddeath30 View Post
    Yes I can still here the FM radio when I go play a video or mp3 in the media section of the program. Both are playing at the same time. Radio and Media
    Mar 2005
    Ok, i will take a look at that, I had some problems with this in develpment, but I thought I had the issue resolved. Can you tell me exactly what steps you took to make it happen, like this: Main Menu - clicked on Radio button, Radio Module - clicked on media button, etc. please describe this so i can figure our where its happening. Thanks.
    Mobile Impact
    Jun 2006
    Houston, TX
    just like u describe. click on media first. let it play then i click on radio and let it play. then i went back to media and both was playing. i had to mute the volume of xm for it to stop
    Mar 2005
    Hmmm, there is no media button on the fm/xm radio module, so describe to me how you get to the radio module then back to media. Main menu - media button, then Media - main menu, Main menu -xm button? is this how you did it?
    Mobile Impact
    Jun 2006
    Houston, TX
    yeah that how i did it
    Mar 2005
    Hmm, thats interesting then because when i do it on my development pc I cannot reproduce that issue, lets see if anyone else is getting this problem. Anyone?
    Mobile Impact
  1. Replies: 570
    Last Post: 11-05-2009, 03:49 PM
  2. Replies: 17
    Last Post: 06-15-2006, 01:46 AM
  3. iGuidance Font Size Fix summary thread
    By Viscouse in forum GPS
    Last Post: 03-28-2006, 07:21 PM
  4. Hacking Iguidance
    By Peoples in forum GPS
    Last Post: 08-28-2005, 07:40 PM
  5. Replies: 2
    Last Post: 08-19-2005, 12:15 AM
