Results 1 to 6 of 6
Thread: Mobile Impact Emulator - 800x480
    Variable Bitrate warnockm's Avatar
    Jun 2004
    Virginia
    Anything special about getting this into 800x480? when i choose a ROM file, the screen looks great, but when Nestopia opens, all MI menus disappear. THe config file shows the screen resolution as 800x480. Perhaps its a setting in Nestopia.
    Progress - VIA EPIA SP8000 | 120 Opus Power Supply & Case | 1GB Ram | 120GB 2.5" Hard Drive | Bluetooth 2.0 | GPRS/3G | Wifi | Road Runner/LSX 2.0 (waiting for a day skin for 3.0) | iGuidance 4.0 | Lilliput 7"
    Mobile Impact Creator reddeath30's Avatar
    Mar 2005
    Placentia, California
    Quote Originally Posted by warnockm View Post
    Its very likely a setting in nestopia that has changed. It should be stretching to fit in the window. Check the settings and see if adjusting the screen/video settings.
    Mobile Impact
    Highly innovative car computer multimedia/entertainment system software.
    http://mobileimpact.biz.tm
    Jun 2004
    Virginia
    Quote Originally Posted by reddeath30 View Post
    I reinstalled w/ the settings that came w/ it. I did change the resolution setting in Nestopia to 800x480, but no luck. Does the emulator run in full screen?
    Mar 2005
    I dont recommend that you run it at full screen, it may be that Nestopia cant do a normal screen stretch like the other emulators, I was lucky with Project 64 in that it does not show the status bar at the bottom when a game is running, but Nestopia actualy can turn that status bar off at the bottom in options. Give that a try.
    Mobile Impact
    Jun 2004
    Virginia
    I figured it out. you have to use a skin thats 800x480. i thought the resolution was set in irunin.ini. I'm using the included CF skin and it works great.
    Mar 2005
    Heh heh, thats good. Thanks for working that out.
    Mobile Impact
