Page 14 of 35 FirstFirst ... 456789101112131415161718192021222324 ... LastLast
Results 131 to 140 of 343
Thread: New Features Progress Update
  1. #131
    Newbie DF-XAF's Avatar
    Sep 2005
    Houston
    Not a big deal. If all I have to do is rename some 12,000 mp3s in order to have a Front End that does damn near everything I want and is the fasted I've found thats not to bad.
    I do have them in Artist/Album folders and I used to name them track # - track Title untill Music Match had a conniption renaming all my music. If there were two different songs by two different artist in completly seperate folders that happened to be (say for instence) "01 - Bone", it wouldnt rename but one of them. At that point I decided to just name them all Artist - Album - Track - Title.
    Back on topic. I'm trying to recreate an issue I had earier that Im not certain if it was a bug or user error.
    When trying to scroll down though the Artist folders the screen would flash repeatedly as if it was trying to move, however it would not scroll at all. I did get it to work by entering one of the folders I could see and then "up Dir" to go back ana then it worked.
    Not sure if it was a freak ocurance or or a bug.
  2. #132
    Mobile Impact Creator reddeath30's Avatar
    Mar 2005
    Fontana, California
    Quote Originally Posted by DF-XAF
    Damn thats alot of songs! I see your dilemma.
    I havent experienced the issue that you mentioned. I have noticed some strange behavior when im trying to navigate and its in between songs. It just seems to stall until it starts the next song, then its fine. Let me know if you can nail it down to a specific event or procedure. Thanks.
    Mobile Impact
    Highly innovative car computer multimedia/entertainment system software.
    http://mobileimpact.biz.tm
  3. #133
    Lockup problem
    I installed the latest version yesterday and now Im having issues. When listening to songs today on two seperate songs and occurances the audio module freezes up. I can surf through the file menu and I can select a song but it wont play. It stays at the same time stamp the whole time like it has been paused yet no sound. The X to exit the program will not work either. If I hit the game button and then the home button it then goes to the exit menu instead of home. I thought it was a XP weird thing the first time but it happened an hour later when headed home from dinner. I did some more testing and even after exiting the program and going back in is still would not play music. If I open media player alone it plays. Its a bit confusing!! Also the status bar on the home page now does not display anything on mine. It stays blue all the time. If I o back to the audio module it is where it is supposed to be.
    Any ideas???
  4. #134
    Mar 2005
    Fontana, California
    Jbyers -> sounds like you may have a corrupted installation or some file isnt working right. I havent heard anyone mentioning this problem. Try Uninstalling the program, and make sure that the C:\Program Files\Mobile Impact directory is deleted. If not delete it manually. Re download the program and install it. Let me know if this cures the problem, if not we can look into it further.
    Mobile Impact
  5. #135
    Jun 2005
    Kent, England
    i'm havign an issue with the screen not refreshing properly sometimes
    i thoguth it had dissappeared but its returned
    it happens when i'm at the 'home' screen and what to go to the 'exit' screen.
    i press the center button but nothing happens, however when i then press one of the normal buttons it operates as though the screen HAS changed
  6. #136
    thanks
    You have a newer version out so I will reinstall and see what happens. Ill keep you posted.
  7. #137
    New skinner
    Aug 18th iGMod was released. On a temp basis, until you build your own skin, can you make Mobile Impact load iGMod instead of directly loading iGuidance. If that can be done then I will be a happy Man!!!
  8. #138
    Mar 2005
    Fontana, California
    Quote Originally Posted by jbyers
    You can make it load by going into the External Apps module and setting it up as the GPS program. Its fairly automated but let me know if you have any difficulties with this. I tested it and realized I had a small bug which is now fixed, so download the new version from my site, then you will have to manipulate the ini file a tiny bit to get iGmod to embed just right.
    Mobile Impact
  9. #139
    Mar 2005
    Fontana, California
    I took a really close look at the menu's and some of the functionality and made some large improvements.
    New Features:
    iTunes, iPod format files now show on Mobile Impact and can be played, all the user has to do is download the 3ivx codec and install it. I have made this available to download from my site. Also to set the music directory back up to select the iPod, all entries under audio in config.ini must be cleared. If iPod is not in File mode, go into iTunes and change it in the preferences.
    Playlist can now add the entire contents of the directory at once to a list.
    If the user has been playing music when they exit, the music starts automatically the next time the program is started.
    Made further improvements on the Game Emulator Module.
    Bug Fixes:
    Runtime error when running an external GPS program in the GPS module -> Fixed
    Main Menus should now be consistent and not get mixed up.
    Mobile Impact
  10. #140
    Mar 2005
    Fontana, California
    I fixed a small bug and the new versions of Mobile Impact and Emulator are available from the website.
    Bug Fix:
    Description, when you go into a directory that has more folders that is showing, then back to one that has only several. You get a runtime error when you try to use the scrollbar -> Fixed
    Mobile Impact
  1. AstraMac Frontend Progress Update
    By iKenndac in forum MacCar
    Last Post: 06-09-2007, 04:52 PM
  2. Completed Requests and Features
    By xBrady in forum GPSSecure
    Last Post: 05-17-2005, 03:43 AM
  3. GPS Update fequency and Dead Reckoning
    By Scouse Monkey in forum GPS
    Last Post: 05-12-2005, 06:46 AM
  4. MediaEngine Development Progress Update
    By CarComp in forum Media Engine
    Last Post: 01-07-2005, 01:53 PM
