I took a long trip from Michigan to Minnesota recently and found that the program had too many bugs to release, so to date...
Completed ->
I have fixed the bugs that I encountered on my trip and several that I found in testing.
I reconfigured the menus so that the main menu is only a single menu instead of a submenu when you hit the media button. Here is a teaser screenshot of the main menu. The next release will also have a new skin called simplistique that I copied from another skin I found on
mp3car.com.
Original Mobile Impact skin
Simplistique skin
I have also added a volume control slider at the top where the song title and volume number shows, It will show the song info and volume number normally but to activate it, you tap on it and the song info and volume number dissappears and the slider shows, after 10 seconds of innactivity it returns to normal showing the song info again or when the user hits any of the volume or module menus.
I have totally redone the DVD/CD player module so that it has playlist, title menu, and several other robust functions. I have also added a cd drive eject button to the dvd/cd module, that is accessed through the playlist screen on the new module.
I fixed the volume control on the XM module so that it is more reponsive and functions without affecting the other volumes.
I updated the SNES9xw to the most current
windows version for the emulator.
I fixed the shuffle function on the media player. The new shuffle works on both the playlist and normal play functions. The new shuffle creates a hidden list of numbers that coincide with the songs, then scrambles the numbers then goes down the list and plays them. No duplicates are encountered and it is very random every time but only works when playing normally. If the user hits the next or previous buttons it uses the original shuffle code, which actually tends to be more random anyway.
To Do ->
I have written an iPod controlling module and will attempt to add it to the media player module.
I will be looking for a good equalizer active x control to add as well. I have search quite in depth and havent found anything yet.
