Page 4 of 35 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 343
Thread: New Features Progress Update
  1. #31
    Constant Bitrate Cravex7's Avatar
    Jul 2005
    Salisbury, England
    yeah reddeath that sounds perfect. the small image would be fine
    Seconded, that sounds great
    "This bloke said to me you haven't got a clue about the damage the soap bar can do to you,
    I tried to see things from his point of view but I couldn't fit my head up his arsehole too."
  2. #32
    Mobile Impact Creator reddeath30's Avatar
    Mar 2005
    Fontana, California
    Quote Originally Posted by jbyers
    The blue theme looks great!! SInce you have the templates for this theme already would it be possible to do a version with the buttons amber and maybe green. I need them amber to match the other lights in my car. I have gotten 3/4 of the way thru creating a skin for the first version nut it seems stupid to finish it if everything is going to move!!!.
    Can you post what you have so far? I Might be able to make it work for the new version.
    Mobile Impact
    Highly innovative car computer multimedia/entertainment system software.
    http://mobileimpact.biz.tm
  3. #33
    FLAC -zip-'s Avatar
    Ontario/Canada
    Here is a shot for you Also the bottom part, where the play, rewind, ff arrows are, I see them if you mouse over that area, but that is all messed up as well.
    Sound Stage
    Eclipse|MTX|Infinity
  4. #34
    Mar 2005
    Fontana, California
    -Zip-
    Thats bizarre. It looks as if you got the form to actually run at 800x600, even though it is hard coded at 640x480. How did you get it to do that? What was your screen settings and refresh rate and all that? Did you alter the skin sizes at all? I would like to know all the details that you can give me so I can try to recreate it. Were the other modules messed up like this too?
    Mobile Impact
  5. #35
    FLAC -zip-'s Avatar
    Ontario/Canada
    OK you are right, it runs fine now because I changed the resolution to 1024x768. I will try and duplicate it and let you know the res and refresh I was running to create the above screen shot.
    Sound Stage
  6. #36
    FLAC -zip-'s Avatar
    Ontario/Canada
    OK seems when it reboots I get the wierd
    screen again. I also get this message at install.
    Also Audio menu, dvd menu etc is all messed up when it is like this.
    Sound Stage
  7. #37
    Mar 2005
    Fontana, California
    -zip-
    Just hit the cancel button and the installation will continue normally, it will error out on several of theses files like this. I am working on the installation to fix this.
    Mobile Impact
  8. #38
    FLAC -zip-'s Avatar
    Ontario/Canada
    Aye that is what I did, continued install.
    Sound Stage
  9. #39
    Jun 2005
    Kent, England
    i can't seem to get mobile impact to use playlists i've created in media player
    surely they are the same file type, etc?
    i can't sit there and manually put in several hundred tracks
  10. #40
    Mar 2005
    Fontana, California
    Quote Originally Posted by GreenBeast
    Sorry, the m3u file created in Mobile Impact is compatible to Windows Media Player, but the m3u file created from Windows Media Player is not compatible in Mobile Impact.
    There is a work around for this. Mobile Impact can only read the full path of the song, and then load this path into the player.
    Open the Windows Media Player m3u file and it should look something like this:
    I am considering making the playlist module better in the future. Right now my main focus is getting the XM Radio module started and adding it to the program. I also am starting another project, and Im sure that I will have lots of bugs and requests with this new version. Hope this helps.
    Mobile Impact
  1. AstraMac Frontend Progress Update
    By iKenndac in forum MacCar
    Last Post: 06-09-2007, 03:52 PM
  2. Completed Requests and Features
    By xBrady in forum GPSSecure
    Last Post: 05-17-2005, 02:43 AM
  3. GPS Update fequency and Dead Reckoning
    By Scouse Monkey in forum GPS
    Last Post: 05-12-2005, 05:46 AM
  4. MediaEngine Development Progress Update
    By CarComp in forum Media Engine
    Last Post: 01-07-2005, 12:53 PM
