Results 1 to 7 of 7
Thread: resuming music playback on hibernate/resume?
    Jun 2005
    Kent, England
    if i use the software itself to hibernate then it continues playback when the PC comes back on however if i hibernate using the ignition it doesn't play when it resumes
    any ideas?
    Mobile Impact Creator reddeath30's Avatar
    Mar 2005
    Placentia, California
    Quote Originally Posted by GreenBeast
    any ideas?
    I dont know why it would do this. The program should resume play using both the Hibernate and Stand By. Have you tried to hit the Hibernate button in the program and does it do the same thing as turning your ignition off? Does your shut down controller actually hibernate the computer or does it shut it down?
    Mobile Impact
    Highly innovative car computer multimedia/entertainment system software.
    http://mobileimpact.biz.tm
    Jun 2005
    Kent, England
    the opus hibernates the pc
    when i use the front end to hibernate it comes back up and plays fine but if i hibernate using my car key then it doesn't.
    strange huh?
    Mar 2005
    strange huh?
    Extremely strange. Might be the difference between a hardware based Hibernate and a Software based. Does the Opus come with software so you can change the settings?
    Mobile Impact
    Jun 2005
    Kent, England
    no it doesn't.
    basically a switched 12v signal goes from the car (ignition) to the opus and that tells the PC to boot up (resume) and when you take key out of ignition it is like pushing the power button, and i've got windows to hibernate the PC when the power button is pressed
    i guess you've never encountered this before then.
    i think i may post in the power section too
    just noticed something else too...when i mute and then unmute the button doesn't change back to the normal mute button
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    This problem is normal with most of the frontends that i've tried, the only one i've had work correctly is Centrafuse, but all the others do the same thing, standby they start playing just fine, but hibernation you have to touch the screen before they start playing again.
    肚子笑痛了
    S60 Install
    Jun 2005
    Kent, England
    ok cheers. i'll just hibernate using frontend which isn't too much trouble, then when i get in i won't have to do anything
  1. Playback skips in both DVD and Music player
    By JayBlazin in forum RR Bug Tracker
    Last Post: 07-28-2005, 06:52 PM
  2. MUSIC PLAYBACK select mp3s wont play
    By antimatter in forum FP Bug Reports
    Last Post: 04-06-2005, 01:41 AM
  3. How to have Music playback at Home Screen?
    By pr3d in forum Media Engine
    Last Post: 03-15-2005, 04:00 PM
  4. Replies: 1
    Last Post: 12-30-2003, 09:28 PM
  5. DISH TV music storage project...
    By claylong in forum General Hardware Discussion
    Last Post: 04-16-2003, 10:08 PM
