Page 4 of 24 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 236
Thread: Mobile Impact Version 3 is now available
  1. #31
    Mobile Impact Creator reddeath30's Avatar
    Mar 2005
    Fontana, California
    Quote Originally Posted by gyro
    Weird, just reinstalled FD, now it looks OK !
    What you showed in the screenshots was Mobile Impact was failing to find FreeDrive correctly after it captured and embedded it. I wonder if anyone else is having this problem. Im glad its fixed now. Let me know if you start having the problem again. Thanks.
    Mobile Impact
    Highly innovative car computer multimedia/entertainment system software.
    http://mobileimpact.biz.tm
  2. #32
    FLAC -zip-'s Avatar
    Ontario/Canada
    Red any plans on adding Sirius as well as XM?
    Sound Stage
    Eclipse|MTX|Infinity
  3. #33
    Mar 2005
    Fontana, California
    Quote Originally Posted by -zip-
    My plans are to only make it run with the custom XMDirect units. I still havent made any progress on it. Im still doing some research. Thanks for checking.
    Mobile Impact
  4. #34
    Maximum Bitrate zPilott's Avatar
    Jul 2004
    Austin
    I am just glad someone finally made a skin with the most frequently used buttons (for me at least ) in the corners.
    |V1 Virtual Display|
    Hard work often pays off over time, laziness always pays off right now.
  5. #35
    Variable Bitrate CARLOS_CET's Avatar
    Aug 2004
    NH
    It's still there, am I the only one getting this? LOL
    1024x768 refresh 75Hz NVidia FX5900 video card XP SP2.
    -zip- .. unfotunately for me your not the only one with this problem. I did what reddeath said..change the fullscreen=0.. but that did not work. Can you are someone please help me. I love this front end. I was using FrodoPlayer but I think that this one is a lot better. Hopefully I can get this problem fixed.
  6. #36
    Mar 2005
    Fontana, California
    Quote Originally Posted by CARLOS_CET
    I really want to help to try to get this fixed. I need some info from you first.
    What windows version are you running?
    What video card do you have?
    What is the settings-> resolution, screen refresh rate, etc.
    If you could give me a screen shot like the one below, it might help.
    You most likely have some sort of screen or program stretch setting.
    Go into your display properties, then click on the Settings tab then click on the advanced button, then if there is a tab that identifies settings for your video card, click on it. The example below shows an Intel video card.
    Mobile Impact
  7. #37
    Aug 2004
    NH
    Thanks reddeath. When I get home I'll take a look at this and give you a screen shot. I'll try and answer some questions now..
    What windows version are you running? WINXP
    What video card do you have? I'll check on this but it's the one built into the VIA M1000 motherboard.
    What is the settings-> resolution, screen refresh rate, etc. I was messing around with the resolution. I had it at 800x600, than 1024x768. But those did not help. I have to check on the refresh rate but I don't think that I ever changed it so it might be 60mhz? But I'll double check.
    Just wanted to give you some basic info. See if any of this helps. Thanks again. Great job on your front end.
  8. #38
    Mar 2005
    Fontana, California
    Thanks to Tim97rs we have a cure! The way to fix this problem is:
    Go into your display properties, on the settings tab hit the advanced button, then change the DPI back to Normal Size (96 DPI).
    Mobile Impact
  9. #39
    Mar 2005
    Fontana, California
    -Zip- -> from the last post -> this should fix it.
    Mobile Impact
  10. #40
    Aug 2004
    NH
    Thank you! That fixed my problem.
  1. VisualDesigner for creating other skins
    By zorro in forum Software & Software Development
    Last Post: 02-17-2007, 09:38 AM
  2. Release CENTRAFUSE BETA 2 (1.3)
    By veetid in forum Centrafuse
    Last Post: 08-01-2005, 03:13 AM
  3. Centrafuse 1.3 Bugs
    By rickster in forum CF Bug Reports
    Last Post: 07-26-2005, 07:51 PM
  4. error - DLL Missing
    By dan__wright in forum AutoTouch
    Last Post: 05-19-2005, 01:12 PM
  5. Nokia Phones
    By [iG] in forum PhoneControl
    Last Post: 01-19-2005, 01:59 AM
