The program is specifically looking for freedrive.exe in the following path.Originally Posted by Nfinite
C:\program files\freedrive\ This cannot be changed as it is hard coded.
The message states that its loading alternative gps program tells me that you set up free drive in the external apps module. The program has internal code that will detect if Freedrive is installed automatically. So go into your config.ini file and remove the GPSPATH and GPSCLASS entries, then make sure that Freedrive is installed in the path that I described. Let me know if this fixes it, if not we can try a few other things.
LinkBack URL
About LinkBacks
