Page 5 of 6 FirstFirst 123456 LastLast
Results 41 to 50 of 57
Thread: NEW VERSION RELEASED - XM and PHOCO Added - GPS IMPROVED!!!
  1. #41
    Mobile Impact Creator reddeath30's Avatar
    Mar 2005
    Fontana, California
    Quote Originally Posted by gyro
    Red, can you make an option in the config to not show the XM thing (for people in Europe ...) instead there could be a radio section be shown (or something else like vehicle maintenance from Lostreception, only with permission off course).
    Thanks, Gyro.
    You could just blacken out the button on the skin and then remember not to click in that area. The skinning and the controls are all hard coded so it would take a considerable additional amount of coding to do this. I would like to accomodate the UK as best as possible however. Is there a reliable and affordable alternative for radio or something to that extent? I could place a check box in the settings to turn this on or off and then when you hit the button it would open this alternative up. I could also alter the skin, but only if there were a decent alternative. Thanks for the input!
    Mobile Impact
    Highly innovative car computer multimedia/entertainment system software.
    http://mobileimpact.biz.tm
  2. #42
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    ok, I just downloaded your program and I have to say i'm really really impressed, I love the interface and the gps intregration. But as I move around the program I keep getting an error about something only being valid when a com port is open (i'll get the exact message in a minute).
    The other problem I noticed right off the bat, 7 out of 10 times when I go to the audio screen it comes up black and I have to click a bunch of times to get the screen to refresh and show me the audio player.
    肚子笑痛了
    S60 Install
  3. #43
    Mar 2005
    Fontana, California
    Quote Originally Posted by jcdillin
    I just finished uploading the fixed version. Go ahead and download it again. The new version is 3.03b. Just unistall the previous version and install this new one. Thanks for the compliments.
    Mobile Impact
  4. #44
    May 2003
    Miami, FL
    ok that seemed to help the media blacking out problem
    but i'm still getting this message after about 30 secs of running the program
    the strange part is that it will give me that message even if I dont go into the XM module but the problem is that the whole program will crash when that happens.
    肚子笑痛了
    S60 Install
  5. #45
    Mar 2005
    Fontana, California
    This is fixed. If you download the latest version from my website it will fix this.
    Mobile Impact
  6. #46
    May 2003
    Miami, FL
    nope, still does it even with the latest version
    肚子笑痛了
    S60 Install
  7. #47
    Mar 2005
    Fontana, California
    Verify the Mi.exe file version for me -> make sure it has a date of 12/22/05 if not then you dont have a good install. Delete the Mobile Impact directory and then install the latest again. Im really certain that this bug is fixed. Let me know. Thanks.
    Mobile Impact
  8. #48
    May 2003
    Miami, FL
    ok, I finally installed this in the car and have been playing with it, with the new version it doesnt give that error anymore, unless you have the XMDirect disconnected, then it will start giving it again.
    2 things i've found though, when not using the XM the line-in is not muted, therefore you get the digital mute static that seems to come from all the XMDirects and also 2 out of 5 times I went into the XM module when I came back from standby I had to retype my channel number back into it. Other times it would come back to the channel correctly.
    I have to say i'm really really happy with the program, my only complaints so far is the having to exit XM before standby and the currently playing info for XM showing up above the GPS window.
    肚子笑痛了
    S60 Install
  9. #49
    Mar 2005
    Fontana, California
    I plan on working on the layout a little bit. This version of the XM was just a tester to see how well it worked. So far it has been fairly successful. One thing that you should know about the XM module that you may already know is that the XM module cant go into standby or hibernate, it only recognizes on or off, connected or disconnected, so if you place the computer in standy by or hibernate the XM will stay on but it will lose the connection to the computer thus producing the error message. So then you could hook up the XM unit to turn off with the ignition, which would be ok, except the fact that the unit was left in the On setting, which will flood the unit with juice as soon as the ignition is turned back on, which is not very healthy for it. Thats why to exit, you have to exit the module, which puts it in the off state to allow the safe elimination of the power source. This is how XM designed it, so that it makes the hardware last longer, thus I programmed the interface with this in mind. Thanks for the suggestions.
    Mobile Impact
  10. #50
    May 2003
    Miami, FL
    Well I have to say out of all the XM's in the frontends yours is awesome, I love having that extra sat info and the numpad entry of the XM channels is incredible. Yeah right now might is powered via ignition so it turns off and off with with the car.
    肚子笑痛了
    S60 Install
  1. New Features Progress Update
    By reddeath30 in forum Mobile Impact
    Last Post: 07-31-2007, 06:54 PM
