Results 1 to 10 of 14
Thread: few problems
    Dec 2005
    Killeen, Tx ( Iraq)
    few problems
    Red, when i play a dvd it plays fine and half screen. when i double click it, it goes to full screen. then it slides all over the screen. it slowly moves toward the lower right cornes of the screen.
    also when mp3's are no matter what setting i try the vizulation(sp) never goes to full screen. how can i fix this.
    thanks again
    sam
    Mobile Impact Creator reddeath30's Avatar
    Mar 2005
    Fontana, California
    Quote Originally Posted by selmerguy
    thanks again
    sam
    Ive seen the issue occur with the DVD if your running your screen at a higher resolution than 800x600 and the problem with the visualization is that you dont have Windows Media Player 9x or better installed. Or you have a touch screen that has a mouse program or touch monitor program running in the background. Check it out and get back to me. Thanks.
    Mobile Impact
    Highly innovative car computer multimedia/entertainment system software.
    http://mobileimpact.biz.tm
    Dec 2005
    Killeen, Tx ( Iraq)
    your right about mp 9x. i will install 10 next week. i thought i had the res set at 800-600 i will check again when my ts gets in next week aswell.
    Dec 2005
    Killeen, Tx ( Iraq)
    ok i downloaded mp10 and the viz. worked great. i went to control panel and cheaked the display settings and it was 800-600. the dvd (at full screen) still slides all over the screen. is there something else i can do? i don't have a dvd codec installed. is this a problem?
    Dec 2005
    Killeen, Tx ( Iraq)
    ok i downloaded a dvd decoder and i still have the problem. what else can i try?
    Mar 2005
    Fontana, California
    Did you turn off all of the features. Remove the check off of the following:
    Seek Bar
    Controls
    Information
    Status
    Take the check off from all of the view items and basically make it look like this:
    Mobile Impact
    Dec 2005
    Killeen, Tx ( Iraq)
    Quote Originally Posted by reddeath30
    Seek Bar
    Controls
    Information
    Status
    ok i did that. and guess what i figured out. it moves the screen when i move the mouse. maybe when my touch screen this wont happen.
    Dec 2005
    Killeen, Tx ( Iraq)
    well my touch screen came in today and it was doa. so i have to send it back to china and have them fix or send me another.
    Dec 2005
    Killeen, Tx ( Iraq)
    got another question for you red. what if i want to us a different emulator. can i set this up? how?
    Mar 2005
    Fontana, California
    Sorry to hear about your screen.
    The current emulators are all pretty much hard coded to the program. They also meet several requirements.
    The main requirement is that they run well and support gamepads/joysticks.
    The next but most important requirement is that they respond to command lines like this:
    "C:\program files\project64\project64.exe C:\Roms\Mario kart64.v64"
    The next requirement is that it has a consistent Window Class. Some emulators change their class every time they run making it impossible to capture and embed.
    The final requirement is that they are able to run and fill most of the screen or are able to stretch to fit in the given space.
    What emulator did you want to run? If its a PS1 emulator. I would have added one but none of them met all the requirements. The one that came closest was PSXeven but it changed its window class on every single load, so It could not be embedded or even sent commands. All of the other PS1 emulators were mostly designed to run games from CD and not from the hard drive.
    Mobile Impact
  1. DWW-700M/MTS12000 Motorized In Dash LCD Problems
    By techy101 in forum LCD/Display
    Last Post: 06-29-2005, 08:12 PM
  2. Audio problems, Epia Sound, and FAQ stuff
    By gothate in forum Newbie
    Last Post: 06-16-2005, 05:04 PM
  3. opus problems
    By studmonk3y in forum Power Supplies
    Last Post: 03-29-2005, 05:09 PM
  4. Hard drive shock problems.
    By Mikesz in forum General Hardware Discussion
    Last Post: 03-21-2005, 04:37 PM
  5. Dell Inspiron 8200 & Lilliput TS problems?
    By bkpsu in forum LCD/Display
    Last Post: 08-15-2004, 02:55 PM
