Results 1 to 10 of 10
Thread: embedding street maps 2006 in MI
    Feb 2006
    I have searched and cannot figure out how to embed streets and trips 2006 into the MI program. When I launch streets and trips 2006 it opens a new window with the s & t software. Is there a way to have it embedded into the MI GPS application? Or google earth
    thanks
    Low Bitrate NoTicketsPlease's Avatar
    Jan 2006
    San Diego, CA
    i was just trying to get google earth to work with MI. I hope support is added for this since google earth is free and has sat. pictures.
    Mobile Impact Creator reddeath30's Avatar
    Mar 2005
    Fontana, California
    Quote Originally Posted by NoTicketsPlease
    Here is how to embed streets and trips:
    Open the Config.ini file in the C:\Program Files\Mobile Impact folder and then
    change/add the following.
    [GPS]
    GPSPATH=C:\Program Files\Microsoft Streets & Trips\streets.exe -> whatever the exe file is.
    GPSCLASS=Afx:00400000:8:00000000:00000000:0006016D
    Do the same thing for Google Earth, but here are the proper entries for it:
    [GPS]
    GPSPATH=C:\Program Files\Google\Google Earth\GoogleEarth.exe
    GPSCLASS=QWidget
    Mobile Impact
    Highly innovative car computer multimedia/entertainment system software.
    http://mobileimpact.biz.tm
    Jan 2006
    San Diego, CA
    Google earth is a program. Download it here: http://earth.google.com/download-earth.html
    You can then use another program called "nmeaGE" to write your gps coordinates to a file that google earth then reads. See the pic below and this thread.
    I just got my gps so I was evaluating mapping programs and this setup looks great plus its free. It does download maps from the net but you can cache them for when you are driving.
    I really hope MI can support this, its my favorite front end!
    Mar 2005
    Fontana, California
    Ok here are the entries for Google Earth:
    [GPS]
    GPSCLASS=QWidget
    This should do it. You will probably need to tweak the left, right, top and left settings to get it to look just right.
    Let me know how things work, and screenshots would be phenomenal! Thanks. I will play with this over the weekend and see how it does.
    Mobile Impact
    Jan 2006
    San Diego, CA
    Thanks for the settings. I havent been able to get them to work. The closest I came was ge(google earth) opened up then I could see the ge startup status in MI. It looked like it was embedded at that point. Then it didnt go much further. I switched to ge and it looks like the GPS menu item had been accessed because it said "This feature is not available in the free version"(paraphrasing) and the gps setup panel was open but all greyed out.
    When you use the mneaGE program to do the gps stuff you dont actually use the gps feature of ge.
    Mar 2005
    Fontana, California
    I played with it a little bit, and yep, it only starts then doesnt embed. So it may take too long for it to load for MI. You could set it up as an external application in the apps module, then it should open with no problems. I admit this is cool as hell! but I dont think that its very touch friendly. If you want; PM me and I will give you some alternatives.
    Mobile Impact
    Dec 2005
    Streets and trips won't work
    Quote Originally Posted by reddeath30
    [GPS]
    [GPS]
    GPSCLASS=QWidget
    I edited the config file to include the above entrys but it still does not work. When I click on GPS Streets and trips opens but it opens in a separate full screen window. The window where it should open in MI says loading alternative GPS program and it just sits there. I have been using centrafuse until now. I don't know if that would have anything to do with it or not. I like Mobile Impact alot and would like to start using it all of the time.
    Your help would be greatly appreciated.
    Dec 2005
    can i embedded street atlas with MI? I wanna it to be like iguidance, the map is within the skin template not as an external gps.
    Mar 2005
    Fontana, California
    Quote Originally Posted by lnb2g
    There are so many variabled in getting other apps to embed properly. You can get it to open an external GPS program by setting it up in the config.ini file as shown above, but most likely wont embed. Give it a try and see if it works.
    Mobile Impact
  1. anyone using Delorme Street Atlas 2006 Plus with RR?
    By blackcar in forum Road Runner
    Last Post: 02-09-2006, 11:31 PM
  2. Replies: 1
    Last Post: 01-12-2006, 01:06 AM
  3. Anyone want Street Atlas USA 2006 cheap?
    By BoyNextDoor in forum GPS
    Last Post: 08-25-2005, 05:03 PM
  4. Replies: 0
    Last Post: 03-03-2005, 11:28 AM
  5. Street Atlas 2004 - Missing Maps
    By jamiewhittingha in forum GPS
    Last Post: 02-02-2005, 11:29 PM
