Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: problem with screen size
  1. #11
    May 2005
    Derbyshire, UK
    I haven't switched my 700IDT on for ages as I need new parts, but iirc there is a setting in the menu to enable auto detection. Is that switched on ??
    I assume you also lose the bottom of the screen of the windows desktop. I see no reason for the software to cause the screen to act differently. As I said though I can't test it on mine currently
    Old setup
    Epia M10k, Cubid 2699R case, 512MB, 40GB 3.5" drive
    New setup
    Optiplex 260SX (2.8GHz P4, 512MB, 30GB, DVD)
    Xenarc 700IDT, USB hub, 802.11g, bluetooth, P2140, P5V
  2. #12
    Mar 2006
    Il
    Quote Originally Posted by markbuts3
    I think auto detect is off and yes I lose the windows parts also
    I will check the detect problem and see if that does it
    thanks
  3. #13
    May 2005
    Derbyshire, UK
    Yes it needs to auto detect and it struggles with lower refresh rates. That's why i suggested upping it
    I just found a vid of mine and it auto detects as 800x600 at 74hz and shrinks it to fit the screen fine.
    Old setup
    New setup
  4. #14
    Mar 2006
    Il
    I just checked there is no way to tunr autodetect on or off you just select it.
    I did that and it still does not fit the screen
  5. #15
    Mar 2006
    Il
    Quote Originally Posted by serious juju
    I think I got it to work call the manufacturer here is how to do it.
    Go to control panel,display,settings,advanced,adapter,list all modes then pick 800 x 600 x 75 htz and that should fix it
  1. LCD screen size for double din opening...???
    By EclipseGSturbo in forum Newbie
    Last Post: 01-30-2006, 12:24 PM
  2. Lilliput - 809GL-80NP - USB/Touch Screen problem
    By dan_t in forum LCD/Display
    Last Post: 06-07-2005, 02:52 AM
  3. Comps Specs and Screen Size
    By Rocky388 in forum Newbie
    Last Post: 05-31-2005, 08:37 PM
  4. Problem with PSOne screen
    By skitchin in forum LCD/Display
    Last Post: 02-08-2005, 06:15 PM
  5. Problem with my screen?
    By Poom in forum LCD/Display
    Last Post: 01-30-2005, 01:25 PM
