I had this problem too. What happened is you set MI up as a front end. I pressed ctl, alt, del and found the c drive to delete MI and then reinstall it. After that go into MI and go to settings. Set explorer as the front end. This should fix your problem.
LinkBack URL
About LinkBacks
