Results 1 to 9 of 9
Thread: I Hit A Wall!!!
    May 2006
    I Hit A Wall!!!
    I installed this software on my home PC to start to learn how to use it. I'm still searching for the right front end. But for some reason with this one, once I rebooted, the software runs right after logon. There is no way to exit the prgram so that windows finished loading. If I do close the program, all that happens is my wallpaper is up. No icons come up, no start menu, no task bar, no anything. Plesae help you guys. Thank You
    Mobile Impact Creator reddeath30's Avatar
    Mar 2005
    Fontana, California
    Quote Originally Posted by billab0ng98
    Go into settings and hit the "set explorer as shell" button, also take the checks off from the hide windows and all that and it should be ok.
    Mobile Impact
    Highly innovative car computer multimedia/entertainment system software.
    http://mobileimpact.biz.tm
    May 2006
    OK. I'm gonna try it when i go home. Thank You
    May 2006
    Still nothing. All I get is my Backround. Thats it.
    Maximum Bitrate Sidewalksalvage's Avatar
    Mar 2006
    NJ/RI
    While computer boots. Hit F8 before the windows load screen. boot into safe mode. Once there, try going to run and type msconfig. Once there click diagnostic startup. This way you can tell when it boots and disable it. Or if you dont want to bother with that. Try unistalling the program....
    Worst comes to worst...back up the pc and reload it
    Brown 2010
    Dec 2005
    Killeen, Tx ( Iraq)
    Need help
    Here you go bud. About 6 topics down from yours.
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Is it windows XP? If so, try hittin Ctrl + alt + del and see if the task manager comes up. If it does, hit file, then new task. Type in explorer.exe and see if you get the start bar back up. If so, yay, and continue from there to fix. If not, poo.
    Tidder
    Try RevFE
    Mar 2006
    NJ/RI
    oh damn i never realized you could do htat.....
    It would have been so much helpful once explorer crashed from time to time.....
    well you learn somehting each day.
    Brown 2010
    Sep 2003
    New Mexico, USA
    Tidder
    Try RevFE
  1. Recent XP update-- Forces to hit enter to login
    By willisan in forum WinNT Based
    Last Post: 05-11-2006, 06:08 PM
  2. Replies: 26
    Last Post: 11-11-2005, 09:43 PM
  3. Have to hit CTRL key to start it ...
    By Don 944 LA in forum CF Bug Reports
    Last Post: 09-28-2005, 11:01 PM
  4. Config popping up when I hit GPS in CentraFuse
    By Chase_UK in forum Map Monkey
    Last Post: 04-13-2005, 04:50 PM
  5. What Have you hit or missed on the freeway ????
    By will1384 in forum Off Topic
    Last Post: 03-05-2005, 09:24 AM
