Results 1 to 5 of 5
Thread: Questions!
    Apr 2006
    Questions!
    1) In view album art mode.. I had it displaying 5 albums across.. now its only 4. I changed the icon size and it did that. I don't know which I like better.. but was wondering if anyone knew this?
    2) When trying to change albums.. sometimes I can't select the album. I was riding w/ my girl and said "ahh f it" .. She goes.. let me try.. stops the song playing and then clicks the album and it loads.. So basically every now and then it wont let me load an album untill I stop the track playing. Why? This happen to anyone else?
    3) Any future for a REBOOT PROGRAM button? Like iGuidance f's up or something and it would be nice to reboot the program.
    4) Anyone else have problems sometimes.. with switching b/t menus.. and have to hit HOME then go to the menu of audio?
    Mobile Impact Creator reddeath30's Avatar
    Mar 2005
    Placentia, California
    Quote Originally Posted by Yellow-Snow
    I would like to see a screen shot of the album art with 4 across instead of 5. I didnt think it was possible as I hard coded the sizing. There is an exit program button, you could hit that, then open it again using a desktop or start menu icon. Ive never heard of having to stop playing to switch to a different album, this im guessing is still in album art viewing mode? What are your specs to your computer? Can you tell me the sequence of how you are switching from one menu to another? Thanks.
    Mobile Impact
    Highly innovative car computer multimedia/entertainment system software.
    http://mobileimpact.biz.tm
    Apr 2006
    System Information
    Time of this report: 6/8/2006, 22:05:45
    Machine name: DEEFAULT
    Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp.051019-1519)
    Language: English (Regional Setting: English)
    System Manufacturer: GATEWA
    System Model: N2DTM026
    BIOS: BIOS Date: 10/19/04 21:11:20 Ver: 08.00.10
    Processor: Intel(R) Celeron(R) CPU 2.66GHz
    Memory: 494MB RAM
    Page File: 119MB used, 1037MB available
    Windows Dir: C:\WINDOWS
    DirectX Version: DirectX 9.0c (4.09.0000.0904)
    DX Setup Parameters: Not found
    DxDiag Version: 5.03.2600.2180 32bit Unicode
    DxDiag Notes
    DirectX Files Tab: No problems found.
    Display Tab 1: No problems found.
    Sound Tab 1: No problems found.
    Music Tab: No General MIDI DLS file was specified in the registry.
    Input Tab: No problems found.
    Network Tab: No problems found.
    DirectX Debug Levels
    Direct3D: 0/4 (n/a)
    DirectDraw: 0/4 (retail)
    DirectInput: 0/5 (n/a)
    DirectMusic: 0/5 (n/a)
    DirectPlay: 0/9 (retail)
    DirectSound: 0/5 (retail)
    DirectShow: 0/6 (retail)
    Display Devices
    Card name: Intel(R) 82865G Graphics Controller
    Manufacturer: Intel Corporation
    Chip type: Intel(R) 82865G Graphics Controller
    DAC type: Internal
    Device Key: Enum\PCI\VEN_8086&DEV_2572&SUBSYS_7147107B&REV_02
    Display Memory: 96.0 MB
    Current Mode: 800 x 600 (32 bit) (85Hz)
    Monitor: Default Monitor
    Monitor Max Res:
    Driver Name: ialmrnt5.dll
    Driver Version: 6.14.0010.3889 (English)
    DDI Version: 9 (or higher)
    Driver Attributes: Final Retail
    Driver Date/Size: 8/20/2004 15:11:00, 37951 bytes
    WHQL Logo'd: Yes
    WHQL Date Stamp: n/a
    VDD: n/a
    Mini VDD: ialmnt5.sys
    Mini VDD Date: 8/20/2004 15:26:00, 737874 bytes
    Device Identifier: {D7B78E66-6632-11CF-FA7C-4D51A3C2CB35}
    Vendor ID: 0x8086
    Device ID: 0x2572
    SubSys ID: 0x7147107B
    Revision ID: 0x0002
    Revision ID: 0x0002
    Video Accel:
    Deinterlace Caps: n/a
    Registry: OK
    DDraw Status: Enabled
    D3D Status: Enabled
    AGP Status: Not Available
    DDraw Test Result: Not run
    D3D7 Test Result: Not run
    D3D8 Test Result: Not run
    D3D9 Test Result: Not run
    Sound Devices
    Description: SoundMAX Digital Audio
    Default Sound Playback: Yes
    Default Voice Playback: Yes
    Hardware ID: PCI\VEN_8086&DEV_24D5&SUBSYS_7147107B&REV_02
    Manufacturer ID: 65535
    Product ID: 65535
    Type: WDM
    Driver Name: smwdm.sys
    Driver Version: 5.12.0001.5240 (English)
    WHQL Logo'd: Yes
    Date and Size: 9/1/2004 12:17:46, 259648 bytes
    Other Files:
    Driver Provider: Analog Devices
    HW Accel Level: Full
    Cap Flags: 0xB5B
    Min/Max Sample Rate: 8000, 48000
    Static/Strm HW Mix Bufs: 1, 0
    Static/Strm HW 3D Bufs: 0, 0
    HW Memory: 0
    Voice Management: No
    EAX(tm) 2.0 Listen/Src: No, No
    I3DL2(tm) Listen/Src: No, No
    Sensaura(tm) ZoomFX(tm): No
    Registry: OK
    Sound Test Result: Not run
    Sound Capture Devices
    Default Sound Capture: Yes
    Default Voice Capture: Yes
    Cap Flags: 0x41
    Format Flags: 0xCCC
    DirectMusic
    DLS Path:
    DLS Version:
    Acceleration: n/a
    Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
    SoundMAX Digital Audio, Software (Kernel Mode), Output, DLS, Internal
    Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
    Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
    Registry: OK
    DirectInput Devices
    Device Name: Mouse
    Attached: 1
    Controller ID: n/a
    Vendor/Product ID: n/a
    FF Driver: n/a
    Device Name: Keyboard
    Attached: 1
    Controller ID: n/a
    FF Driver: n/a
    Poll w/ Interrupt: No
    Registry: OK
    USB Devices
    + USB Root Hub
    | Vendor/Product ID: 0x8086, 0x24DE
    | Matching Device ID: usb\root_hub
    | Service: usbhub
    | Driver: usbhub.sys, 3/5/2006 10:40:32, 57984 bytes
    | Driver: usbd.sys, 8/23/2001 07:00:00, 4736 bytes
    Gameport Devices
    PS/2 Devices
    + Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
    | Matching Device ID: *pnp0303
    | Service: i8042prt
    | Driver: i8042prt.sys, 8/3/2004 17:14:38, 52736 bytes
    | Driver: kbdclass.sys, 8/3/2004 16:58:34, 24576 bytes
    + Terminal Server Keyboard Driver
    | Matching Device ID: root\rdp_kbd
    | Upper Filters: kbdclass
    | Service: TermDD
    | Driver: termdd.sys, 8/4/2004 00:01:08, 40840 bytes
    + Microsoft PS/2 Mouse
    | Matching Device ID: *pnp0f03
    | Upper Filters: egxfilter
    | Service: i8042prt
    | Driver: mouclass.sys, 3/20/2006 03:42:47, 23040 bytes
    + Terminal Server Mouse Driver
    | Matching Device ID: root\rdp_mou
    | Upper Filters: mouclass
    | Service: TermDD
    + USB Touchscreen Controller(Universal)
    | Vendor/Product ID: 0x0EEF, 0x0001
    | Matching Device ID: usb\vid_0eef&pid_0001
    | Service: xtouch
    | Driver: xtouch.sys, 3/22/2006 12:59:26, 77952 bytes
    DirectPlay Service Providers
    DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
    DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
    DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
    DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
    Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
    IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
    Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
    Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
    DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
    DirectPlay Test Result: Not run
    Registry: OK
    DirectPlay Adapters
    DirectPlay8 Modem Service Provider: Sony Ericsson W800 USB WMC Modem
    DirectPlay8 Modem Service Provider: Sony Ericsson W800 USB WMC Data Modem
    DirectPlay8 Serial Service Provider: COM1
    DirectPlay8 Serial Service Provider: COM3
    DirectPlay8 Serial Service Provider: COM6
    DirectPlay8 Serial Service Provider: COM7
    DirectPlay8 TCP/IP Service Provider: MS TCP Loopback interface - IPv4 -
    DirectPlay Voice Codecs
    Voxware VR12 1.4kbit/s
    Voxware SC06 6.4kbit/s
    Voxware SC03 3.2kbit/s
    MS-PCM 64 kbit/s
    MS-ADPCM 32.8 kbit/s
    Microsoft GSM 6.10 13 kbit/s
    TrueSpeech(TM) 8.6 kbit/s
    DirectPlay Lobbyable Apps
    Disk & DVD/CD-ROM Drives
    Drive: C:
    Free Space: 17.2 GB
    Total Space: 19.5 GB
    File System: NTFS
    Model: WDC AC420400D
    Drive: D:
    Free Space: 81.1 GB
    Total Space: 114.5 GB
    File System: NTFS
    Model: WDC WD1200BB-22GUA0
    Mar 2005
    Yellow-Snow -> thats pretty cool. I didnt know that by changing the icon size and spacing on the desktop would affect the control on the program. I see that your machine has plenty of horsepower to run the program so not the problem. I do notice that you have a mouse buttons program running by one of your screenshots, Its possible that it is interfering with the program. I have a T-View cheepy monitor and it had a mouse program that ran on it to change from left to right clicking and when it was running, the visualization in the media player would not go to full screen until this mouse program was disabled. Give it a try and see what happens. Does this problem happen all the time or does it only happen on occasion?
    Mobile Impact
    Apr 2006
    um that mouse program was loaded after i had the problem.. and yes i recently just turned it off ( it came with the new lilliput drivers). Imo thats not the problem..
    idk if we are talking about the same thing.. the problem is..
    "2) When trying to change albums.. sometimes I can't select the album. I was riding w/ my girl and said "ahh f it" .. She goes.. let me try.. stops the song playing and then clicks the album and it loads.. So basically every now and then it wont let me load an album untill I stop the track playing. Why? This happen to anyone else?"
    That was with normal icons also.. it only happens every now and then.. its not a BIG problem just maybe you might want to look into it.. ill see if i can get it to do it everytime.. just remember my actions..
    Maybe sometimes the first album wont load.. b/c i know sometimes i click it.. ok wont load.. well let me click another album and it loads.. or maybe its something w/ that folder.. anywho.. ill try to remember what i do to cause it.
  1. Bunch of questions .. New around here.
    By Timm3h in forum Newbie
    Last Post: 06-22-2005, 02:28 AM
  2. questions and more questions
    By cortinaking in forum Newbie
    Last Post: 06-16-2005, 03:02 PM
  3. Box and In-Dash setup questions
    By Pale Rider in forum Fabrication
    Last Post: 06-11-2005, 03:40 PM
  4. Replies: 6
    Last Post: 05-25-2005, 12:53 PM
  5. Lots of questions.. long post.
    By rach in forum Newbie
    Last Post: 11-13-2004, 11:53 PM
