Results 1 to 8 of 8
Thread: Best way to set/install Windows or MI
    Jun 2006
    As the title really. Whats the best way to configure/reinstall windows for the fastest/most stable MI install.
    Anything in particular i should look to remove/keep in / tweak?
    Jul 2006
    Springfield, IL
    Assuming you are referring to XP, the methods are numerous. Some methods are a bit more shady than others (any of the mini XP builds by eXperience - do a torrent search) or a nice legit method is XPLite (http://www.litepc.com).
    "It's a blessing . . . and a curse."
    Jun 2006
    Thanks, had a lok at xplite before but really trying to make my mind up if thats any better than just doing a cleanish (ie no cr*p) xp install with min drivers fo the system in use..
    Mobile Impact Creator reddeath30's Avatar
    Mar 2005
    Placentia, California
    Quote Originally Posted by geeky_hawkes View Post
    One thing to be carefull about when using the slim xp installs is, they leave out the driver library, so if you install new hardware and it requires windows drivers for any reason it wont be able to find it, or it may not be able to install it either. I tried a slim install of xp once and had so many issues, I wont ever do it again.
    Mobile Impact
    Highly innovative car computer multimedia/entertainment system software.
    http://mobileimpact.biz.tm
    Jul 2006
    Springfield, IL
    Quote Originally Posted by reddeath30 View Post
    Very true, however that's a perfectly acceptable trade-off for most people, especially in a CarPC environment. It is indeed something to be aware of though.
    Jun 2006
    Thats what i suspected. Even worse in the case of using a laptop as a base unit i imagine. Reddeath whats your performance like using a full xp install?
    Mar 2005
    It takes roughly 20 to 25 seconds for bootup, and about 10 to 15 seconds for shut down. This is XP Pro, with Sp2, .Net 2x, Media Player 10, Direct X 9.x, Xvid codec, and Power DVD installed. Absolutely no critical security patches have been installed, no antivirus, etc. those are what slow you down.
    My system is the following
    MSI Cube PC - Mega 651
    P4 2.53 ghz
    256Mb Ram
    40Gb hard drive
    Sound Blaster Live MP3 soundcard.
    Mobile Impact
    Jun 2006
    Sounds good, im planning on running a laptop install so will mostly hibernating the system anyway so that should shave a few seconds off here and there. Thanks for your help
  1. New Frontend for Windows and Linux
    By gbr in forum Other Cool Front Ends
    Last Post: 01-21-2009, 09:55 PM
  2. Installing Windows 2000 Pro on a 1GB Microdrive
    By JeremyM in forum WinNT Based
    Last Post: 05-07-2005, 10:56 PM
  3. Windows Freeze When Crank, Crank again windows unfreeze
    By antimatter in forum Power Supplies
    Last Post: 07-27-2004, 01:40 AM
  4. Windows ME and MediaCar
    By dug1967 in forum MediaCar
    Last Post: 04-15-2004, 02:30 PM
  5. Running windows with no monitor?
    By BLACKOUT in forum General Hardware Discussion
    Last Post: 03-14-2001, 11:56 AM
