Results 1 to 4 of 4
Thread: N64 Issues
    Feb 2007
    N64 Issues
    I installed the 64 emu, and when I try to run mario kart in MI, MI reverts back to the last screen I was in while starting the emulator, then if I switch back to the emulator screen it pauses or freezes up. So far the NES and Sega emu's are working just fine though.
    Mobile Impact Creator reddeath30's Avatar
    Mar 2005
    Placentia, California
    Quote Originally Posted by bhladeoghrass View Post
    Project 64 gives a message when you start it for the first time it has a dialog that prompts for the language with an Ok button. Once you click this once, then you dont see it or have to deal with it again. Try opening project 64 from the start menu and then try to open it again from Mobile Impact and see if you still have the problem. Let me know how it goes.
    Mobile Impact
    Highly innovative car computer multimedia/entertainment system software.
    http://mobileimpact.biz.tm
    Feb 2007
    Yeah I already went through that, I found one of the problems was I had Project 64 set to pause when it lost focus. I'm still not sure why when i start MarioKart through MI it goes away from the emu screen though.
    oh and thanks for the quick reply so far this program is great and i like all the help out there
    Edit:
    So what kind of video settings are you guys using for Project 64 because I'm thinking maybe it's one of those that's causing this issue. I didn't really change much except tell it to use a windowed size of 800X600 which works with the exception of the bottom bar covering up part of the game.
    Mar 2005
    Edit:
    I just use the default settings that it comes with. I dont make any changes That may be part of your issue as well.
    Mobile Impact
  1. Touchscreen Issues w/Hibernation & CNX-P1290
    By jmciver in forum Power Supplies
    Last Post: 12-20-2006, 08:48 PM
  2. Verizon Novatel 620 issues
    By MobiTekLink in forum Wireless Communications
    Last Post: 12-02-2005, 04:35 PM
  3. Having instability issues with your M7NCG 400 and/or XP install?
    By wallaceacura in forum General Hardware Discussion
    Last Post: 07-20-2005, 02:29 AM
  4. Power issues in 03 Mustang
    By tj!2k4 in forum Power Supplies
    Last Post: 12-22-2004, 02:16 PM
  5. Installing an XBOX & N64
    By sdashiki in forum General Hardware Discussion
    Last Post: 11-30-2004, 01:20 AM
