This is a perfect example of why external programs are so difficult to embed, because many of them change their classname. The code relies on this to work. The new version uses a slightly different approach, it uses the process identifyer, then using additional coding, it identifies the class name of the running program, then uses that to embed it. Its not 100% however because I have found one particular instance where problems embedding will occur with mapmonkey as it has the same classname when it starts, but then changes it to something else after the spash screen shows. So unfortunately there is no known resolution for this.
LinkBack URL
About LinkBacks
