yes? wait it works now, i dunno what i did tho, i think i forgot to delete the xml file or something, like it crashes if there is an xml file that does not match the folder in the config file???
You deleted the configuration file?
I read "CAN BUS", now that would be great for any mercedes users such as myself.
I would love to get the steering wheel controls working again and maybe even the in dash display as CAN BUS is a 2 way comms system.
Craig
Audi S8 supercar
Modded Xbox 400GB HD
Rear 7" screen & navplus
Toyota Hiace Van
Shuttle PIII 866 256Mb 10GB OPUS powered
MediaCar & Mappoint 2004
Custom fit 7" TFT VGA TSK
What are the system requirements to run this? Any special software?
Progress Meter:
[|||||!||||'] 95% complete
It's in... it's finally installed!!!! But never finished!
"It works! It works! I've finally invented something that works!" -- Doctor Emmit Brown
This was optimized for a pentium 1.2 celeron, and no other software is necessary, ours does it allWhat are the system requirements to run this? Any special software?
Dvd plugin comin soon? If it had that, id deleted all this other crap I have on there. It would be good if I could switch between music folders too. I listen to alot of audio books. 70 mile comute to work everyday you see. I have them in different folders to make it easier.
I ran the installer, it installed .Net 2.0 and after this it starts the program install.
Right after it says ready to start the install and press next it says:
The installer was interrupted before Mobile Media Center Alpha Realease 2 could be installed. You need to restart the installer to try again.
I tried this and also tried rebooting same error.
Event Viewer says:
Event ID: 11708
Product: Mobile Media Center Alpha Release 2 -- Installation Failed.
What can I do to fix this?
VWMAN
"Live Long And Prosper"
car: VW Cabriolet '90
puter: M10000(toasted), Lilliput, CarNetix
status: In Progress
Looks Cool, I will try it out over the weekend also. Just curious....any plan for XM support?
Stop Buying New Music CD's.
Hit The RIAA where it lives.
Indash Motorized 7", Epia Nehimiah, 512 MB, 80 GB, DVD, Wireless G, XP Pro, XM PCR, Kenwwod 5 Channel 1200 Watt Amp.
That thing eats up resources like well I don't know...but it does. It loaded the first time slowwwly then after i closed it and opened it again it wouldn't load but it would lag my system some like it was going to. Then when I changed the configuration file to point to the path where my media is it still would not load
CarPC install is starting to come along again...
