When I play mp3's and switch tracks the first doesnt stop playing. So im hearing two songs at the same time. This happens alot when the visuals are on the screen.
Printable View
these visualizations make me cream my pants. frodo definately has some competition, i really like this program, and its just alpha!!
ok...im gonna try to answer many questions all at once.....
firstly the video crashing issue has been fixed and we will be posting a new installer tonite that fixes alot of those little bugs you all have reported including that one....
second, we will have keyboard shortcuts...it will be on beta 1
the scrolling marquee you can actually grab and move into view so the speed isnt that important...
eventually when we get a final flawless product it WILL have a settings page to allow all these things you ask for to be preferances.
both xm and fm SHOULD have independent volume controls if you have them plugged into your line input..
if this is not the case let me know
I hope that helps, so keep your eyes open for the update release
I agree. The visualizations are pretty wicked. My concern is a lot of them run really slow on my Atlhon XP 2500 w/512M RAM. In full screen mode, CPU is usage is between 75-99%. While just playing an MP3 with the mini-vis going, CPU usage is baout 20-35% for the bars and 50-70% for the double bar.
(Playing music videos: CPU usage is 30-50% small, 40-50% medium, and 10-25% full).
Anyone else notice this?
Derek
Quote:
Originally Posted by Ill1
Same here.Quote:
Originally Posted by zijester
Code:See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at HybridMobile.Media.Video.VideoPanel.get_Position()
at MobileMediaCenter.MmcForm.timer_Tick(Object sender, EventArgs e)
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.Callback(IntPtr hWnd, Int32 msg, IntPtr idEvent, IntPtr dwTime)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.3600.0
Win32 Version: 2.0.40607.16 (beta1.040607-1600)
CodeBase: file:///C:/WIN_XP/Microsoft.NET/Framework/v2.0.40607/mscorlib.dll
MobileMediaCenter
Assembly Version: 0.5.1000.3
Win32 Version: 0.5.1000.3
CodeBase: file:///C:/Program%20Files/Hybrid%20Mobile%20Technologies/Mobile%20Media%20Center%20Alpha%20Release%205/MobileMediaCenter.exe
CodeBase: file:///C:/WIN_XP/assembly/GAC_MSIL/System.Windows.Forms/2.0.3600.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WIN_XP/assembly/GAC_MSIL/System/2.0.3600.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WIN_XP/assembly/GAC_MSIL/System.Drawing/2.0.3600.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Xml
CodeBase: file:///C:/WIN_XP/assembly/GAC_MSIL/System.Xml/2.0.3600.0__b77a5c561934e089/System.Xml.dll
HybridMobile.Media
Assembly Version: 1.0.1726.42825
Win32 Version: 1.0.1726.42825
CodeBase: file:///C:/Program%20Files/Hybrid%20Mobile%20Technologies/Mobile%20Media%20Center%20Alpha%20Release%205/HybridMobile.Media.dll
Intellified
Assembly Version: 1.0.5000.0
Win32 Version: 1.0.5000.0
CodeBase: file:///C:/Program%20Files/Hybrid%20Mobile%20Technologies/Mobile%20Media%20Center%20Alpha%20Release%205/Intellified.dll
HybridMobile.Mmc
Assembly Version: 1.0.1726.40690
Win32 Version: 1.0.1726.40690
CodeBase: file:///C:/Program%20Files/Hybrid%20Mobile%20Technologies/Mobile%20Media%20Center%20Alpha%20Release%205/HybridMobile.Mmc.dll
System.Data
CodeBase: file:///C:/WIN_XP/assembly/GAC_32/System.Data/2.0.3600.0__b77a5c561934e089/System.Data.dll
HybridMobile.Xmlpcr
Assembly Version: 1.0.1726.40692
Win32 Version: 1.0.1726.40692
CodeBase: file:///C:/Program%20Files/Hybrid%20Mobile%20Technologies/Mobile%20Media%20Center%20Alpha%20Release%205/HybridMobile.Xmlpcr.dll
fm_avermedia
Assembly Version: 1.0.1726.40695
Win32 Version: 1.0.1726.40695
CodeBase: file:///C:/Program%20Files/Hybrid%20Mobile%20Technologies/Mobile%20Media%20Center%20Alpha%20Release%205/Plugins/Radio/fm_avermedia.dll
fm_dlink
CodeBase: file:///C:/Program%20Files/Hybrid%20Mobile%20Technologies/Mobile%20Media%20Center%20Alpha%20Release%205/Plugins/Radio/fm_dlink.dll
HybridMobile.DirectX.DirectShow
Assembly Version: 1.0.0.1
Win32 Version: 1.0.0.1
CodeBase: file:///C:/Program%20Files/Hybrid%20Mobile%20Technologies/Mobile%20Media%20Center%20Alpha%20Release%205/HybridMobile.DirectX.DirectShow.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
Derek
ok, my PCR is an optical input so maybe thats why it doesn't work for me. Is there an app launcher?
Thanks for the info.
I copied this from when I posted it in the other bug report thread. It is still a problem:
I have a large database of songs. I go and pick an artist to play. Up comes all of that artists songs. I will be listening and then it will get to a song that isn't by that artist. Took me a bit to figure it out but if there are any duplicate names in the database ( same song name, differant artists ) it will play one or the other. For example, I am listening to Artist A with a song called Song A. If there is a Artist B with a song of that same name as Song A, but is actually Song B, it will either play Song A for both artists or song B for both artists.
Thanks!
D-Link radio testing
Volume up and down work OK
When I click in the box the station list would be expected in I get this:
Switching between radio and mp3 is not graceful - have an mp3 playing, click on radioonbutton.png then the power button to turn the radio on, and I'll have radio and mp3 playing at the same time.Code:************** Exception Text **************
System.IndexOutOfRangeException: There is no row at position -2.
at System.Data.DataRowCollection.get_Item(Int32 index)
at MobileMediaCenter.MmcForm.stationListBox_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
mscorlib
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.40607/mscorlib.dll
MobileMediaCenter
CodeBase: file:///G:/CarPC%20test/Hybrid/MobileMediaCenter.exe
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.3600.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.3600.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.3600.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.3600.0__b77a5c561934e089/System.Xml.dll
HybridMobile.Media
CodeBase: file:///G:/CarPC%20test/Hybrid/HybridMobile.Media.dll
Intellified
CodeBase: file:///G:/CarPC%20test/Hybrid/Intellified.dll
HybridMobile.Mmc
CodeBase: file:///G:/CarPC%20test/Hybrid/HybridMobile.Mmc.dll
System.Data
CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Data/2.0.3600.0__b77a5c561934e089/System.Data.dll
HybridMobile.Xmlpcr
CodeBase: file:///G:/CarPC%20test/Hybrid/HybridMobile.Xmlpcr.dll
fm_avermedia
CodeBase: file:///G:/CarPC%20test/Hybrid/Plugins/Radio/fm_avermedia.dll
fm_dlink
CodeBase: file:///G:/CarPC%20test/Hybrid/Plugins/Radio/fm_dlink.dll
CodeBase: file:///G:/CarPC%20test/Hybrid/HybridMobile.DirectX.DirectShow.dll
enabled.
For example:
<configuration>
</configuration>
Now go back to mp3, change track - I have 2 mp3's playing. Back to radio and back to mp3, and I can add a third layer of mp3. For some reason there is a bug in the way that mp3's are handled in the switch to radio.
I can't seem to save new stations to a station list. How is it intended that this will work. I'm happy to have a single list. If you like, I can send you through the details as to how Radiator structure their station lists.
Hope this is a helpful start.
C!
I just sat down and tryed the new version of mmc and this version is a big improvment. :D. The new features in this version are great the xm sat. is perfect. The interface is still the same pretty much, But its simple, simple is better. So far i rate this version a A+ work. Hope to see some new versions in the future. GREAT JOB :cool:
