What happened to mini mode?
Printable View
it was a bit buggy, and looked a bit cheesy......we will release it with beta one, sorry
xmpcr is supported......what do you mean? you have to change the com port in the config file to reflect the one that windows assigns it...default is com4
get an error everytime i try starting it up. "This program has preform...." cant even run it for the 1st time.
Guess I should have known that already. :o Just got a lead on a pcr and got alittle excited.
(goes to change his shorts) :D
Me either, same problem.
Quote:
Originally Posted by Motoko
Ran fine for me. Just installed over-top. But still mov files won't play, just crashes mmc.
DVD playback still doesn't work.
I found that too....change your config file to look like this:
<?xml version="1.0" encoding="utf-8"?>
<configuration>
<appSettings>
<add key="skin" value="Default" />
<add key="musicFolder" value="" />
<add key="videoFolder" value="" />
<add key="miniVisual" value="SpectraGrid.svp" />
<add key="audioVisual" value="RabbitHole.svp" />
<add key="lastRadioFrequency" value="88.1" />
<add key="cecuPresent" value="false" />
<add key="cecuPort" value="COM1" />
<add key="xmPort" value="COM8" />
<add key="ignitionMode" value="Standby" />
</appSettings>
</configuration>
Ben built the installer and it has his folder path in it.....of course you dont have the same folder path so the audiofolder and videofolder need to be blank
can you be more specific other than "DVD playback still doesnt work"Quote:
we will check into mov's
My DVDs have no audio. But Video is fine.
