http://www.mp3car.com/vbulletin/showthread.php?t=33497
Posts #1 and #5....![]()
Check out my hopefully useful site...
www.hobbybotics.com
It's still under design but it is functional
Posts 4 and 9
MMC 5.01:
*Terminator 3 DVD.... video, no audio
*Rocky 2 DVD.... Freezes MMC at FBI warning
*Varsity Blues DVD.... Freezes MMC while buffering
*Apollo 13 DVD.... Freezes after DVD menu
*Local .mov's won't play at all and crash MMC
DVD drive: Sony DVD-RW DRU-510A
DirectX 9.0c
This is the new features and plugin request thread. Please read through the already posted suggestions before posting. More than likely someone may have already thought of it. I've added the stuff from the old thread and removed some of the features that have been implemented.
This was originally managed by Derek and I hope he can pick up where he left of someday soon...
Updated: 03/16/2005 by Ben
[LEGEND] [x] = Completed, [o] = work in progress, [ ] not started
Mobile Media Center (iMeedia) Feature Requests
HIGH PRIORITY
[o] MapMonkey Integration
[o] Application Embedding (More Robust)
[o] Playlists Support (native, m3u, pls)
[ ] Create/Name/Delete multiple playlists
[ ] Web Browser!
[ ] Dynamic DB Updates (Threaded, Background)
[ ] Phone Control integration
[x] Rear view Camera
[ ] Minimizing external apps?
[ ] OSK work with external apps and embedded apps
[ ] Save Song/Playlist/List mode/etc settings on the fly in various periods... also on exit.
[ ] Resume settings on load or resume from hibernate
[o] XM/SIRIUS Support (Robust and better then now!)
[ ] Shortcut for shutdown (keyboard) and bypass confirmation screen
[ ] Add error catching/logging to areas that could cause problems
[o] Audio Gapless playback for supported files
[o] Audio Cross-fading
[o] Configure power button for shutdown/exit/hibernate, etc
[o] Smart Shuffle (allow previous history)
[x] 10-Band Equalizer
[ ] TV Tuner Support
[o] ICE Cast / Shout Cast Support
[ ] Change speech initiation command (i.e. MMC -> Computer)
[o] Mouse Wheel Support
[ ] Toggle Track elapsed/remaining time
[o] CD Ripping with CDDB support
[ ] Volume Slider
[ ] CONFIG SCREEN
[ ] Screen resolution support
[ ] Localization, multiple languages
[ ] Media synchronization
[ ] DVD Rip to DivX
[o]Controls that work with every screen, include song info, etc
NORMAL PRIORITY
[ ] iPod integration
[ ] More voice commands (relays, video, gps, etc)
[ ] Radio support (TV/FM tuners, Radiator, Seths, USB dongles)
[ ] Show Album tracks in track order
[ ] Volume Normalization/Tracking per song
[ ] Speech Command Groups (MMC> MUSIC, PLAY, NEXT, VOLUME 50% <THANKS) and add timeout if "THANKS" is never said.
[ ] Put number folders in correct order for browse mode...
[ ] While scrolling thru music or in different list, do not play next song.
[ ] EQ Presets / Per song EQ settings, save in database.
[o] Album Art - if more then one pic, slide show, and default image for none.
[ ] OBDII / CAN
LOW PRIORITY
[ ] PIM (Calendar, Planner, Organizer, PDA sync, Appointments, etc)
[ ] Control either wave or master volumes with volume controls (configurable)
[ ] Remember Shuffle status/order between loads.
[ ] M2V video file support
[ ] Back button (would allow us to remove the .. at the beginning of the browse list.
[ ] Winamp Visuals!!!
[ ] When playing videos, etc (turn off screen saver)
[ ] Minimize to taskbar shortcut
[ ] Reuse the old Media.xml...
[ ] Video/DVD combined?
[ ] Winamp NSV Playback
[ ] Write current media info to log file to be used in other programs...
[ ] Scrolling labels? (Can slow system down if not careful...)
[ ] Visual slide show (Random mode with possible time settings)
[ ] Visual - go full screen automatically after so many seconds (configure it)
[ ] Password prompt to close MMC
Derek (d_sellers1) & Ben (Bitoholic)
Progress [||-------]
View my Worklog to see some of my progress.
Downgraded Progress - Starting with another car... 09/13/06
This will be done from this point forward.
Thanks!
I am closing this thread
Ben S. Stahlhood II
Hybrid Mobile
MMC/Transcend Developer
http://www.hybrid-mobile.com/
http://www.cocoamachine.com/
http://weblogs.asp.net/bstahlhood/
http://www.hybrid-mobile.com/mp3car/
user: mp3car
pass: betanext
As always uninstall old version, delete any droppings left over after uninstall and install new version.
This version has some better DVD handling code we want you to test out and give us the results. We are hoping for better results then the previous versions. Visual preferences now save to config file on exit. Quicktime codecs are included int he installer, so MOV and QT files should work. Version 0.5.4 will have more of the bug fixes reported over the past week plus a new DVD fix based on the feedback we get.
Thanks!
Ben S. Stahlhood II
Hybrid Mobile
that is really weird..the splash screen comes on...but the software does not load....the task manaer shows that the player keeps increasing the space it takes on ram...but never loads...is anyone else experiencing this? or is my computer being retarted!
DICE Los Angeles
You need to edit the Mobile Media Center.exe.CONFIG file. Looks like when Hybrid compiled MMC, they still had some settings set for use on their computer. Make yours look like this:
<?xml version="1.0" encoding="utf-8"?>
<configuration>
<appSettings>
<add key="skin" value="Default" />
<add key="musicFolder" value="" /> CHANGE THIS LINE!!!
<add key="videoFolder" value="" /> THIS ONE TOO!!
<add key="miniVisual" value="SpectraGrid.svp" />
<add key="audioVisual" value="RabbitHole.svp" />
<add key="lastRadioFrequency" value="88.1" />
<add key="cecuPresent" value="false" />
<add key="cecuPort" value="COM1" />
<add key="xmPort" value="COM4" />
<add key="ignitionMode" value="Standby" />
</appSettings>
</configuration>
Derek
