Thread: Archive
  1. #1161
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    I had problems creating the database from my folder of music. I had around 6,000 songs. The program would crash when building the database. But when I copied about 25 songs into another folder it worked fine. Also the original folder was in my shared documents and the new folder was on my desktop, I'm not sure if that matters.
    Also, I can't play any of the videos I have. when I click play I get an error and the program crashes and I have to exit.
    Code:
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.NullReferenceException: Object reference not set to an instance of an object.
       at HybridMobile.Media.Video.VideoPanel.get_Position()
       at MobileMediaCenter.MmcForm.timer_Tick(Object sender, EventArgs e)
       at System.Windows.Forms.Timer.OnTick(EventArgs e)
       at System.Windows.Forms.Timer.Callback(IntPtr hWnd, Int32 msg, IntPtr idEvent, IntPtr dwTime)
    ************** Loaded Assemblies **************
    mscorlib
        Assembly Version: 2.0.3600.0
        Win32 Version: 2.0.40607.42 (beta1.040607-4200)
        CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.40607/mscorlib.dll
    MobileMediaCenter
        Assembly Version: 0.5.1000.3
        Win32 Version: 0.5.1000.3
        CodeBase: file:///C:/Program%20Files/Mobile%20Media%20Center%205/MobileMediaCenter.exe
        CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.3600.0__b77a5c561934e089/System.Windows.Forms.dll
    System
        CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.3600.0__b77a5c561934e089/System.dll
    System.Drawing
        CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.3600.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Xml
        CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.3600.0__b77a5c561934e089/System.Xml.dll
    HybridMobile.Media
        Assembly Version: 1.0.1728.26079
        Win32 Version: 1.0.1728.26079
        CodeBase: file:///C:/Program%20Files/Mobile%20Media%20Center%205/HybridMobile.Media.dll
    Intellified
        Assembly Version: 1.0.5000.0
        Win32 Version: 1.0.5000.0
        CodeBase: file:///C:/Program%20Files/Mobile%20Media%20Center%205/Intellified.dll
    HybridMobile.Mmc
        Assembly Version: 1.0.1726.40690
        Win32 Version: 1.0.1726.40690
        CodeBase: file:///C:/Program%20Files/Mobile%20Media%20Center%205/HybridMobile.Mmc.dll
    System.Data
        CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Data/2.0.3600.0__b77a5c561934e089/System.Data.dll
    HybridMobile.Xmlpcr
        Assembly Version: 1.0.1728.22401
        Win32 Version: 1.0.1728.22401
        CodeBase: file:///C:/Program%20Files/Mobile%20Media%20Center%205/HybridMobile.Xmlpcr.dll
    fm_avermedia
        Assembly Version: 1.0.1726.40695
        Win32 Version: 1.0.1726.40695
        CodeBase: file:///C:/Program%20Files/Mobile%20Media%20Center%205/Plugins/Radio/fm_avermedia.dll
    fm_dlink
        CodeBase: file:///C:/Program%20Files/Mobile%20Media%20Center%205/Plugins/Radio/fm_dlink.dll
    HybridMobile.DirectX.DirectShow
        Assembly Version: 1.0.0.1
        Win32 Version: 1.0.0.1
        CodeBase: file:///C:/Program%20Files/Mobile%20Media%20Center%205/HybridMobile.DirectX.DirectShow.dll
    ************** JIT Debugging **************
    To enable just-in-time (JIT) debugging, the config file for this
    application or machine (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
        <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the machine
    rather than being handled by this dial
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
  2. #1162
    Maximum Bitrate d_sellers1's Avatar
    Mar 2002
    Austin, Texas
    Quote Originally Posted by The Grinch
    ...while viewing videos in full screen, when the next video starts to play you loose full screen (you see all the controls), and the mouse pointer is no longer visible.
    I too have lost the mouse cursor but I can't figure out what I did to make it do that...
    Derek
    Progress [||-------]
    View my Worklog to see some of my progress.
    Downgraded Progress - Starting with another car... 09/13/06
  3. #1163
    The land of polar bears and nekkid blonds
    Well that didn't work for me...
    Tried installing in a different location, pointing towards different media locations, but no luck... still stuck at square one.
  4. #1164
    Variable Bitrate HybridMike's Avatar
    Orlando, Florida
    we want to test the DVD codec, because that is what we want to include in our software....the only way to test is to have you guys use it....once we get it working properly it will probably only install the codec if there is not one on your machine....however, the blaze codec has a very good picture, Ive used both winDVD and PowerDVD filters and this one looks WAY better...just a bit picky getting it to run properly...but we will get it
  5. #1165
    Super Moderator xBrady's Avatar
    USA
    I noted this on the bug report page yesterday. It only happens with videos. If this was done intentionally, it would make more sense for the pointer to disappear after X seconds, and reappear when the mouse is moved.
    I prefer to have it work the way it does because I use a touchscreen.
    Installed.
    -GPSSecure- - GPS Tracking
  6. #1166
    Maximum Bitrate Bitoholic's Avatar
    Port Saint Lucie, FL
    Talking DVD Patch
    Please test this as soon as you can...
    Replace the same 3 files on the root of MMC Install folder.
    http://www.hybrid-mobile.com/mp3car/...3_dvdpatch.zip
    user: mp3car
    pass: betanext
    Thanks!
    Ben S. Stahlhood II
    Hybrid Mobile
    MMC/Transcend Developer
    http://www.cocoamachine.com/
    http://weblogs.asp.net/bstahlhood/
  7. #1167
    Talking DVD Patch
    user: mp3car
    pass: betanext
    Thanks!
    Ben S. Stahlhood II
    Hybrid Mobile
  8. #1168
    Variable Bitrate AlienEclipse's Avatar
    Jul 2003
    Dunedin - New Zealand
    Quote Originally Posted by HybridEngineer
    user: mp3car
    pass: betanext
    Thanks!
    unfortunately, no change to fault. Still no video or audio and DVD drive busy reading data. Tested with several DVD's, all same problem.
    We are, will have and forever will be...
    But not tommorrow!
  9. #1169
    Jul 2003
    Revision 3 works fine for me, with the exception of DVD.
    But not tommorrow!
  10. #1170
    Maximum Bitrate nFiniteTuning's Avatar
    Tijeras, NM
    I got a serious question. I've been testing these diff programs before I install my carputer, and I have chosen these two programs to be the nicest:
    MMC
    MediaEngine
    But for the number one program, MMC just totaly blew my mind away on things, the spectrum screen, the kick *** screen saver while music is playing. But there is one thing I really want that I didn't see it having....An external applications feature like MediaEngine. Is there any chances of this being done to this program? Because I'm going to use my carputer for everything and I'd like it to all go through one program. I want to watch DVD's and video's on my hard drive, listen to cd's and mp3s, listen to the radio, and when I'm bored and hangin out at the local spot to hang out (by my shop), i wanna sit back, and go into MMC (if it becomes possible) and go into a menu of applications I have installed like Internet Explorer, Need For Speed: U2, stuff like that. I have Media Engine running like that and thats what I like. But I love the format of MMC soo much better. I also had to have a 7 band eq, and from what I'm sein from a little button on MMC, there's gonna be audio adjustments.
    If you guys at Hybrid can get back to me on this, I'll even donate cash to do it. $50, $75, $100..whatever it takes for this program to suit my needs. Please get ahold of me about this. This Carputer stuff was just announced to me yesterday and it blew my mind since I'm a huge car guru and computer guru....didn't think Mini ITX mobo's were bein used this way.
    1987 Pontiac Fiero GT
    XPCarputer Coming Soon
    [IIIIIII---] 70% Complete
    XPC Model SN41G2V2
    AMD AthlonXP 1800+
    2× Mushkin 256MB DDR
    Pioneer DVDRW
    80GB 7200RPM UltraATA HD
    Windows XP MC2005
    XM Satellite Radio
    •ñFïnïtε Τחטіתģ•
  1. Alpine
    By more mods in forum RR Skins
    Last Post: 04-10-2008, 06:34 AM
  2. Frodo's Files Archive!
    By kujosan in forum FrodoPlayer
    Last Post: 09-24-2006, 10:24 PM
  3. Archive
    By liquid_smoke in forum PhoneControl
    Last Post: 07-23-2006, 05:01 AM
  4. FOR THE LOVE OF ALL THATS HOLY AND DECENT, NO MORE ARCHIVE POSTS!!!
    By sleddog4 in forum General Hardware Discussion
    Last Post: 10-30-2000, 10:25 PM
