How about this one? Pretty clean I think. Oh, Dracos, I jacked your button for the skin. Hope you don't mind. If you do I'll remove it.
Printable View
My Epia M10000 uses a lot of CPU too but MMC is working flawless. I noticed also that the spectrum analyzer / VuMeter eats a good % on my CPU.
@Dracos: seems that your system needs more RAM. The high cpu usage should be related both to low memory (when phisical available become so low the system keeps swapping a lot) and heavy cpu load on visuals.
lol, i jacked it from google anyways. i dont care in the slightest. :)
Well, yea. I forgot to say that it was being tested on an old P2 450mhz w/128mb RAM.
Im sure it wouldnt be so bad if i ran it on my P4 3.1Ghz w/512mb DDR PC3200 FX5950
Ill be honest though, MMC was still running flawlessly although it was at 100% on Vis screen.
any updates on when rev 6 will be outQuote:
Originally Posted by HybridMike
Post them here...
Well... here it is. Last release before Beta 1.
Please test the hell out of this thing. All past bugs, etc.
DVD should be working pretty damn good I hope. I got resources down by about 30 - 40% on our test.
http://www.hybrid-mobile.com/mp3car/
user: mp3car
pass: betanext
Have fun!
- Ben
will test
Well i don't know about anyone else, but mine ain't going!
It shows the splash screen and thats it. It leaves the process running at 0% CPU and 52-54MB Ram usage. Occasionally i get the Microsoft Debugger come up, but it doesn't tell me anything. I have tried it with no paths set in the config file, paths with trailing slash, and paths without. It just don't go.
And yes i did completely remove the previous version.
Running XP Pro + SP2, fully up to date.
did you delete the old Hybrid Mobile Technologies folder after uninstalling?Quote:
because it will leave the media.xml file in there and it has to be deleted when you install a new version...so make sure you have no paths in the config file and delete the media.xml...then try it
Mike
