ok i figured out the reason it gave me the could not get interface error was because a dvd was in my dvdrom drive, which it apparently doesnt like at all.
Printable View
I installed and I am getting an "Specified argument was out of range of valid values. Parameter name: handle. Any suggestions? I get this error when i click on a song to play.
We do require that DirectX 8.1 and above is installed. On the download page it says no requirements. This was based on the fact that Windows XP comes with 8.1 installed. This is a bad assumption since people will still need DirectX 8.1 on Windows 98 and Windows 2000.Quote:
Originally Posted by tribaldaze
Tribaldaze, can you give me more specifics on your machine specs? Also, do you have more then one sound card installed?
Yeah I have a bit of slowdown with 32bit color. Im runing an athlon 1.3 with 512 of ram. When I changed it to 16 bit it worked fine. It ate up alot of resources on my home pc too. And thats athlon 2400 with 1 gig of ram.Quote:
Originally Posted by HybridEngineer
Quote:
Originally Posted by zijester
Where do you see the problem being? When you play videos mostly? All over the place? Thanks for the feedback.
I am donwloading the programm right now!!!:)
Can't wait to try it after having read the whole thread!!!
Would you consider including TeleType as a GPS???:):)
Quote:
Originally Posted by DjBac
We will integrate anything that has an SDK / API and of interest to our users.
Just through the visuals. It really depends on the visual im using. Some use less resources than others. Theres no slowdown on other parts of the program.Quote:
ok I installed it... but having issues.
I have around 60 gigs of music, when I open it, it starts to create a database then pukes... the "such and such encountered an error" error.
So I go it and pull all the music out but about a gig, all is fine, loads up nicely, so I start copying music back, however it doesn't add the newly copied music to the database. I'm stuck with only being able to access the original folder that it built on first execution.
Don't know, this is a major deal breaker for me, and it was the same problem I experienced with the first release.
Isn't it supposed to add music on the fly? Is there any way to make it rebuild the database and not die in the process?
Other then that I really like the way it looks..
Hi.
I only have one question. Will this software be able to read video files like ripped DVD files (VOB files from the hard disk) what about DIVx and AVI.
