Page 15 of 236 FirstFirst ... 567891011121314151617181920212223242565115 ... LastLast
Results 141 to 150 of 2359
Thread: Archive
  1. #141
    Sep 2003
    Baltimore, MD
    ok i figured out the reason it gave me the could not get interface error was because a dvd was in my dvdrom drive, which it apparently doesnt like at all.
    2003 Jetta GLI
    1.8 ghz intel pentium 4
    256 mb ram
    dvdrom
    xenarc 700tsv
    Status - 90% - need to finish bondoing
  2. #142
    Jun 2004
    Getting error
    I installed and I am getting an "Specified argument was out of range of valid values. Parameter name: handle. Any suggestions? I get this error when i click on a song to play.
  3. #143
    Maximum Bitrate Bitoholic's Avatar
    Port Saint Lucie, FL
    Quote Originally Posted by tribaldaze
    We do require that DirectX 8.1 and above is installed. On the download page it says no requirements. This was based on the fact that Windows XP comes with 8.1 installed. This is a bad assumption since people will still need DirectX 8.1 on Windows 98 and Windows 2000.
    Tribaldaze, can you give me more specifics on your machine specs? Also, do you have more then one sound card installed?
    Ben S. Stahlhood II
    Hybrid Mobile
    MMC/Transcend Developer
    http://www.hybrid-mobile.com/
    http://www.cocoamachine.com/
    http://weblogs.asp.net/bstahlhood/
  4. #144
    Aug 2003
    Milwaukee
    Quote Originally Posted by HybridEngineer
    Are you having problems with slow down or lag? I use a TX3 and it works great in my car... just curious.
    Yeah I have a bit of slowdown with 32bit color. Im runing an athlon 1.3 with 512 of ram. When I changed it to 16 bit it worked fine. It ate up alot of resources on my home pc too. And thats athlon 2400 with 1 gig of ram.
  5. #145
    Quote Originally Posted by zijester
    Where do you see the problem being? When you play videos mostly? All over the place? Thanks for the feedback.
    Ben S. Stahlhood II
    Hybrid Mobile
  6. #146
    Maximum Bitrate DjBac's Avatar
    Jun 2004
    GREECE/Athens
    I am donwloading the programm right now!!!
    Can't wait to try it after having read the whole thread!!!
    Would you consider including TeleType as a GPS???
  7. #147
    Quote Originally Posted by DjBac
    We will integrate anything that has an SDK / API and of interest to our users.
    Ben S. Stahlhood II
    Hybrid Mobile
  8. #148
    Aug 2003
    Milwaukee
    Just through the visuals. It really depends on the visual im using. Some use less resources than others. Theres no slowdown on other parts of the program.
  9. #149
    LAME :) lopan's Avatar
    Dec 2003
    Clarksville TN
    ok I installed it... but having issues.
    I have around 60 gigs of music, when I open it, it starts to create a database then pukes... the "such and such encountered an error" error.
    So I go it and pull all the music out but about a gig, all is fine, loads up nicely, so I start copying music back, however it doesn't add the newly copied music to the database. I'm stuck with only being able to access the original folder that it built on first execution.
    Don't know, this is a major deal breaker for me, and it was the same problem I experienced with the first release.
    Isn't it supposed to add music on the fly? Is there any way to make it rebuild the database and not die in the process?
    Other then that I really like the way it looks..
  10. #150
    Maximum Bitrate tolisn's Avatar
    Dec 2003
    Greece
    Hi.
    I only have one question. Will this software be able to read video files like ripped DVD files (VOB files from the hard disk) what about DIVx and AVI.
  1. Alpine
    By more mods in forum RR Skins
    Last Post: 04-10-2008, 06:34 AM
  2. Frodo's Files Archive!
    By kujosan in forum FrodoPlayer
    Last Post: 09-24-2006, 10:24 PM
  3. Archive
    By liquid_smoke in forum PhoneControl
    Last Post: 07-23-2006, 05:01 AM
  4. FOR THE LOVE OF ALL THATS HOLY AND DECENT, NO MORE ARCHIVE POSTS!!!
    By sleddog4 in forum General Hardware Discussion
    Last Post: 10-30-2000, 10:25 PM
