Rev 8:
I noticed that when I'm playing a DVD and I use the reverse cam them go back to the DVD, the DVD begins to skip.
Ive read that you need to use a line in rather than mic if you want decent quality music anyways. I havnt tested it though. I bought a usb sound device that has digital in/out, 6 channel out (3-mini) ((or is it midi??)) and a mic in. It sounds good and it was only $30 at fry's. Now I can have extra channels and controls for bass.
2.4 celeron
150 watt OPUS
micro atx
xp pro
tv/radio tuner card
audigy
Dual monitor Radeon
802.11G Mimo
xm pcr
dvd
gps
8" Lilliput touch screen
IGuidance
dual optimas
battery isolator
15" screen
My Truck
Rev 8:
2.4 celeron
150 watt OPUS
micro atx
xp pro
tv/radio tuner card
audigy
Dual monitor Radeon
802.11G Mimo
xm pcr
dvd
gps
IGuidance
dual optimas
battery isolator
15" screen
My Truck
Did you all know that? I'm just wondering why the button is desquised. Anybody know?
2.4 celeron
150 watt OPUS
micro atx
xp pro
tv/radio tuner card
audigy
Dual monitor Radeon
802.11G Mimo
xm pcr
dvd
gps
IGuidance
dual optimas
battery isolator
15" screen
My Truck
The EQ isn't expected to work until Beta 1.
Carputer progress meter: [-----|]
Carputer gadget meter: [--|---]
I'm hoping that this is the right place to post as I am showing Alpha 5 Rev 8, so here goes:
-When I press the 'Mobile Media Center' text or the ‘Hybrid’ symbol on the main screen I get an error that states ‘An unhandled exception has occurred in your application., blah, blah’ along with the statement that an ‘Object reference not set to an instance of an object.’ along with the following details.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at HybridMobile.Media.MediaLibrary.BuildDatabase(Stri ng path)
at MobileMediaCenter.MmcForm.ProcessMmcMessages(Strin g message)
at MobileMediaCenter.MmcForm.buttonPanel_MouseDown(Ob ject sender, MouseEventArgs e)
at System.Windows.Forms.Control.OnMouseDown(MouseEventArgs e)
at System.Windows.Forms.Control.WmMouseDown(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.3600.0
Win32 Version: 2.0.40607.42 (beta1.040607-4200)
CodeBase: file:///C:/WINNT/Microsoft.NET/Framework/v2.0.40607/mscorlib.dll
MobileMediaCenter
Assembly Version: 0.5.1000.3
Win32 Version: 0.5.1000.3
CodeBase: file:///C:/Program%20Files/Hybrid%20Mobile%20Technologies/Mobile%20Media%20Center%20Alpha%20Release%205%20Re v%208/MobileMediaCenter.exe
CodeBase: file:///C:/WINNT/assembly/GAC_MSIL/System.Windows.Forms/2.0.3600.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINNT/assembly/GAC_MSIL/System/2.0.3600.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINNT/assembly/GAC_MSIL/System.Drawing/2.0.3600.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Xml
CodeBase: file:///C:/WINNT/assembly/GAC_MSIL/System.Xml/2.0.3600.0__b77a5c561934e089/System.Xml.dll
HybridMobile.Media
Assembly Version: 1.0.1787.1562
Win32 Version: 1.0.1787.1562
CodeBase: file:///C:/Program%20Files/Hybrid%20Mobile%20Technologies/Mobile%20Media%20Center%20Alpha%20Release%205%20Re v%208/HybridMobile.Media.dll
Intellified
Assembly Version: 1.0.5000.0
Win32 Version: 1.0.5000.0
CodeBase: file:///C:/Program%20Files/Hybrid%20Mobile%20Technologies/Mobile%20Media%20Center%20Alpha%20Release%205%20Re v%208/Intellified.dll
System.Data
CodeBase: file:///C:/WINNT/assembly/GAC_32/System.Data/2.0.3600.0__b77a5c561934e089/System.Data.dll
HybridMobile.Xm
CodeBase: file:///C:/Program%20Files/Hybrid%20Mobile%20Technologies/Mobile%20Media%20Center%20Alpha%20Release%205%20Re v%208/HybridMobile.Xm.dll
HybridMobile.DirectX.DirectShow
Assembly Version: 1.0.0.1
Win32 Version: 1.0.0.1
CodeBase: file:///C:/Program%20Files/Hybrid%20Mobile%20Technologies/Mobile%20Media%20Center%20Alpha%20Release%205%20Re v%208/HybridMobile.DirectX.DirectShow.dll
HybridMobile.Mmc
CodeBase: file:///C:/Program%20Files/Hybrid%20Mobile%20Technologies/Mobile%20Media%20Center%20Alpha%20Release%205%20Re v%208/HybridMobile.Mmc.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
I had the same type of problem when my music database became corrupt. I had to uninstall and reinstall to fix it.
We have a build that makes use of the relays on the cecu, still getting it cleaned up.
I do it all the time. make sure you don't have windows firewall blocking you.
I have the same problem with Realtek AC97 audio.Originally Posted by AlienEclipse
